Suspension & Brakes Theory, alignment, spring rates....
BOUNCE BOUNCE BOUNCE
Old Nov 21, 2005 | 07:39 AM
b18c1srfun's Avatar
Default BOUNCE BOUNCE BOUNCE
OK, so in hindsight just putting some TENZO-R adjustable coilovers may not have been the best way to go, my car is bouncy, any suggestions?
Old Nov 21, 2005 | 08:23 AM
cambopheonix56's Avatar
Default Re: BOUNCE BOUNCE BOUNCE (b18c1srfun)
How far did you drop it? Because it may be your struts are bottoming out.
Old Nov 21, 2005 | 02:59 PM
HiProfile's Avatar
Full tein or omni coilover shock combo...that's the better way.
Otherwise you need to extend the shock mount (top hat) an inch, or at least cut your bumpstop in half. That bounce is the shocks bottoming out. Raising it an inch and getting adjustable shocks would also help.
Old Nov 21, 2005 | 08:44 PM
bad-monkey's Avatar
stock shocks?
are they blown?
bounce? or thud? or combination of both?
Old Nov 22, 2005 | 06:26 AM
b18c1srfun's Avatar
Yes, they are stock shocks and no, they do not make noise. How do I go about extending the shock mount? I'm pretty sure that is what'll fix her.
Old Nov 22, 2005 | 07:41 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1srfun &raquo;</TD></TR><TR><TD CLASS="quote">Yes, they are stock shocks and no, they do not make noise. How do I go about extending the shock mount? I'm pretty sure that is what'll fix her.</TD></TR></TABLE>
if they are like most coil-overs the spring rates are too high for most shocks to handle. i say try and buy some better shocks. also how far did you drop it?
Old Nov 22, 2005 | 10:24 AM
bad-monkey's Avatar
if it's not making a thud, then you're not bottoming out. when you bottom out/hit the bumpstops, it's something you can definitely feel/hear.
if it's just bouncing too much, it's a damping issue. projecteg is right about the spring rates and the stock damper's inability to dampen the oscillations of the spring aka keep the car from bouncing around.
aftermarket shocks or softer springs are your solution.
taimysho0
Aug 17, 2008 05:12 PM
Asway
70
Dec 13, 2006 08:12 PM
deeweezy187
Jun 16, 2005 02:15 PM
Otherguy
Nov 1, 2004 06:24 PM
everlast
Aug 24, 2004 05:50 AM
