Aftermarket Exhaust? Don't have a flexible gasket? Use aluminum foil!!!!!
Old Nov 21, 2005 | 04:55 AM
mikeunreal's Avatar
Default Aftermarket Exhaust? Don't have a flexible gasket? Use aluminum foil!!!!!
So i bought a catback and apparently the guy that had the car before me had new pipes made, and it was all one piece. There are 2 ring gaskets, called flexible gaskets you use to connect the pipes. I didn't have it obviously, so guess what. We used aluminum foil. We wrapped it around like a gasket and it just molded to the pipes. We connected the 2 and bam, it worked fantasticly. No exhaust leaks, nothing. It was amazing. And the best part is, the idea came from the ITR forum. Haha, go hondatech.!!!!
Old Nov 21, 2005 | 05:00 AM
ZacCarter's Avatar
It might work for a week.
Old Nov 21, 2005 | 05:10 AM
mikeunreal's Avatar
Default Re: (ZacCarter)
the actual gasket is the same concept. it creates a seal so exhaust gases don't leak. I think this is going to work just fabulously. If not, then ill get a gasket.
Mike
Old Nov 21, 2005 | 05:13 AM
ZacCarter's Avatar
Are you using it in between 2 collectors, or are you useing it as a flex tube?
Old Nov 21, 2005 | 05:18 AM
mikeunreal's Avatar
its in between the 2 pipes, the pipe where the s is, and the pipe straight pipe. i used the actual gaskets they sent to connect the pipes, this is just the ceramic ring thing that goes on it. we had the actual ring gasket to connect the exhaust manifold to the cat. its the same piece. we just ghettod the other one bc it wasnt as important . works great.
Old Nov 21, 2005 | 05:34 AM
dumped_ej1
Guest
Posts: n/a
Default Re: (mikeunreal)
cutting corners ghetto rigging is even the last resort, it should never come to that.
Old Nov 21, 2005 | 05:56 AM
sicones's Avatar
Default Re: (dumped_ej1)
I would use you that for temporary use, then go find the right gasket..
Old Nov 21, 2005 | 06:06 AM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal &raquo;</TD></TR><TR><TD CLASS="quote">the actual gasket is the same concept. it creates a seal so exhaust gases don't leak. I think this is going to work just fabulously. If not, then ill get a gasket.
Mike</TD></TR></TABLE>
Same concept, different materials. That foil trick of yours might work for a little while. I'd suggest ordering a real gasket soon though. Nothing more annoying than an exhaust leak.
for thinking of alternative ways of doing stuff though. If you had some tin snips you could have cut yourself a new gasket out of a soda can too.
Old Nov 21, 2005 | 06:38 AM
mikeunreal's Avatar
Default Re: (IslandSi)
well in times of need you have to do what u can. my old exhaust didnt have this gasket so i had to do something. ill order a real one.
Mike
mjf6866
Mar 15, 2015 02:32 PM
3Rd_gEn_LuDE
Feb 10, 2011 05:02 PM
bOOsTiNSoHcVtEc
Jul 14, 2005 03:42 PM
redlseg
May 18, 2005 12:58 PM
DAVE15401
Nov 27, 2004 10:46 AM
