rear disc brake swap....a little bit of play in the hub....y?
just finished my gsr brake conversion on my 96 ek....fronts are perfect...but there is a little bit of play in the hub on both rears so it causes the rotor and wheel to wobble also.
what could the problem be? bad bearings?
i tightened the 32 mm axle nut as much as it would go...thinking it might solve the problem...but there is still a little bit of play in it...
im concerned about driving with this problem....any input would be aprreciated.
is there really a washer? i guess the previous owner took the washers out...cuz the axle nuts were real loose when i first got them....
just checked on hondapartsdeals.com the washers r 6 bucks a pop.
i hope that will solve the problem...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda »</TD></TR><TR><TD CLASS="quote">btw why dont you use the washers out of your old setup ? they are the same </TD></TR></TABLE>
i had drums in the rear b4...
Honda/Acura PN 42324-SB2-020 is the same for drum or disc brakes. They might sell them at autozone & kragen, and are available at some online sites...
http://www.rockauto.com/ref/RB...4.jpg ... sold in packs of 5 for $1.31 each ($6.55 total) at rockauto.com (plus you can get a 5% discount there if you do some coupon hunting).
They are also used in the front (same part #s for front/rear for 99-00 EX/SI models, don't know about other models/years).
Hope this helps.
JasonGhostz
Hope this helps.
JasonGhostz
thanks for all the input....i used the washer from my old drums set up....but too bad i ordered a set from honda before i read this post
97CivicExNoob
Jan 18, 2009 10:20 AM
akteamster
Suspension & Brakes
Nov 22, 2005 07:54 PM
Echo7847
Jan 23, 2003 06:25 PM
