Rotating mass balanced
Old Mar 12, 2002 | 09:12 AM
jt-sport's Avatar
Default Rotating mass balanced
Im an engine builder in my lil city. Until know i always did pistons ,pins ,rods and valve train balance by my self (except crank, and flywheel or other that rotating). i did it part by part (even for the wrist pin fastener) with 0.2 gram tolerance.
but untill now i still dont know how many gains we got from balancing rotating mass (in this word we ignore about the aim of minimizing vibration for purpose of comfortable feeling).
if there no big gains (under 1 hp). i would rather sit down and stay than balancing that stuff anymore. I hate to waste a lot of time and sufferance for under 1 hp jobs
(grand tourismo playsation says it gains more than 4 hp LOL) hahahaha
Regards
Odie Knownothings
Old Mar 12, 2002 | 09:17 AM
RyanR's Avatar
Default Re: Rotating mass balanced (jt-sport)
Balancing the rotating mass isn't really meant to give you power. It's to lengthen the life of your engine and make it more reliable. If your running an engine with a lot of power or an engine turning high rpms, it will benefit being balanced even more. When you balance the pistons, rods, rings, pins, do you also have the crank, flywheel, clutch, crank pulley balanced?
Old Mar 12, 2002 | 09:40 AM
jt-sport's Avatar
Default Re: Rotating mass balanced (RyanR)
Yup. Off course i balance 'em (crank ,flywheel ,clutch pressure plate, pulley ,etc) on the balance shops.
uhmmm... just to lenghten the engine life and realibility..
Old Mar 12, 2002 | 10:57 AM
dwilson's Avatar
Hey guys i was just reading the post and had a quick question. I am a new engine builder and am fixing to do my first build up. I just went and had my crank balanced. Do i need to just wait and get all of my hardware ( pistons, rods, pressure plate, etc.) together and then take them and get it all balanced together or wil aftermarket part come pre balanced.
Thanks, David
Old Mar 12, 2002 | 11:06 AM
jt-sport's Avatar
Default Re: Rotating mass balanced (dwilson)
You just bring them all to the balance shop ,and they will balance it all separately.
Piston , rod , etc will be balance part by part .
flywheel, crank ,pulley was whole balanced together.
ls_on_boost
Oct 9, 2011 04:29 AM
turbotime
Aug 4, 2003 09:48 AM
Davanca
Apr 22, 2003 04:33 PM
DLB1994
Jun 11, 2002 06:35 AM
