hooking up ipod/mp3 player to old aftermark headunit.?
Old Nov 20, 2005 | 10:15 AM
RnEpmc's Avatar
Default hooking up ipod/mp3 player to old aftermark headunit.?
alright so im wondering if i should get a mp3 player or not. i figure if i can hook it up to my headunit then it would be worth it. so all you audio guys is it possible??? my headunit is pretty old. 5 plus years.
the 2 white and red plugs are line outs.
if its too big ill edit it
Old Nov 21, 2005 | 04:25 AM
B18C_EJ8's Avatar
Nope. The only way you're gonna get sound from your iPod through that deck is with a wireless FM modulator.
Old Nov 21, 2005 | 10:46 AM
EGPrelude's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Nope. The only way you're gonna get sound from your iPod through that deck is with a wireless FM modulator. </TD></TR></TABLE>
Actually, they do have "wired" FM modulators that have antennas going into the radio with the car antenna going into the module.
Personally I prefer these units as they are less prone to static and noise from bad reception.
Old Nov 21, 2005 | 11:57 AM
B18C_EJ8's Avatar
Good call...
Let me rephrase...
The only way you'll get sound through that deck is with an FM Modulator, wired or wireless...
Old Nov 22, 2005 | 05:23 PM
StorminMatt's Avatar
Default Re: hooking up ipod/mp3 player to old aftermark headunit.? (RnEpmc)
Perhaps the best option here (in terms of sound quality) would be to buy an amp (even a small one, if you don't want ALOT of power). Then get a line-level switch so that you can switch between the iPod and head unit.
Old Nov 23, 2005 | 04:12 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Perhaps the best option here (in terms of sound quality) would be to buy an amp (even a small one, if you don't want ALOT of power). </TD></TR></TABLE>
And then what? Run all new lines to the speakers and then worry about having to turn off the radio to listen to the iPod? And then not have any flexibility to adjust bass and treble? And then have to control the volume off the iPod?
Yeah... Great idea man...
Get an FM Modulator. It'll sound just fine (especially with the direct connect one). Even with the cheaper wireless ones, I think it'll sound pretty good. Not perfect, but most sound pretty good.
Old Nov 24, 2005 | 04:32 AM
Get an FM Modulator. It'll sound just fine (especially with the direct connect one). Even with the cheaper wireless ones, I think it'll sound pretty good. Not perfect, but most sound pretty good. </TD></TR></TABLE>
Or just get a new head unit. From my experience, FM modulators are pretty crappy. I would prefer the trouble of running a separate amp rather than running an FM modulator.
Old Nov 25, 2005 | 09:48 AM
BigJ5's Avatar
Well, I use my ipod like a ***** in both my vehicles...
in my sol I have a premeire deck where pioneer made a pretty nice little unit that integrates the ipod nicely. esp for 130 bux cdn I was more than happy
in my beater van I have a poo-quality sony deck that has nothing so I use the griffin fm trans unit. It's not bad, but not great. There is a little static sometimes, but it's super quiet which is the part I hate the most. (meaning that the amp unit in the griffin is kinda crappy, but I figure it's the radio laws) The sweet part about it is when I'm working in my shop I can broadcast to the radio, which has significantly better reception than my car.
If you had amps powering your speakers and only used the deck for processing I would recommend a switch so that the ipod can go directly through a crossover network and to each amp bypassing your deck, but since you kinda have a low-end deck you most likely don't have that kinda setup.
I would recommend you use an FM transmitter, I got mine on sale for 26 bux cdn....seems to be the best bang for your buck solution here.
Old Nov 26, 2005 | 10:30 AM
BigJ5's Avatar
honda_sol_vtec
Audio / Security / Video
Oct 21, 2008 10:07 AM
thatasiankidtony
Oct 9, 2006 02:47 PM
Deerslayer
16
Sep 19, 2004 08:46 AM
bassisliffe
70
Sep 9, 2004 04:06 PM
silverciv97
Sep 4, 2004 11:37 AM
