car bogs when my vtec kicks in
Old Nov 20, 2005 | 09:42 AM
xtegb16x's Avatar
Default car bogs when my vtec kicks in
well my car was working fine untill it started bogin when my vtec was engaging so i was thinking it was time for an oil change so i bought 'quaker state oil 10-30' and i changed the oil and my filter and it still does the same thing even worse?? i dunno wat it is?? might it be my oil becuz i switched over from valvoline 10-40
Old Nov 21, 2005 | 01:32 PM
eas156's Avatar
Default Re: car bogs when my vtec kicks in (xtegb16x)
I dont think it is your oil. ie weight. How did your oil look when you changed it? maybe fuel or fire, check rotor and cap plugs plug wires. The only thing I can think of is if there is still crap in your engine from the old oil.
Old Nov 21, 2005 | 02:11 PM
loudassVTEC's Avatar
It sounds to me, like your timing might have jumped a tooth. My engine jumped time by a tooth on each cam gear. All the sudden, it sounded bad ***, like I had a set of cams or something. It made a lot of noise, but didn't go anywhere. When VTEC came in, it bogged until it got to 5500, and then pulled pretty hard. I changed my head gasket, and realized my timing was off, so I fixed it. It's not loud anymore, but it pulls a lot harder, and it didn't bog anymore. But I switched to OBD-1, and that changed my VTEC engagement to 5500, and it made my car soooo much faster. But anyway, check your timing.
Old Nov 21, 2005 | 06:38 PM
dtm03's Avatar
Default Re: car bogs when my vtec kicks in (loudassVTEC)
I got the same problem, but I dont think my timing belt is off, because it runs great until vtec. its like the car falls flat on its face. hopefully someone has some insight on this problem
Old Nov 21, 2005 | 06:49 PM
boosted_integ's Avatar
check cap and rotor plugs etc!!!!!!!!!!!
Old Nov 21, 2005 | 07:04 PM
dtm03's Avatar
Default Re: (boosted_integ)
if that was it, wouldnt it do it all the time? not just when vtec is supposed to kick in?
Old Nov 21, 2005 | 10:06 PM
SlammedDC2's Avatar
Semper Fidelis
My car was/is doing the same thing. I took it to Honda and had one of the techs (my buddy) put it on the diagnostic. And come to find out my ECU is shot. Mine bogs down from 4600 (engagement) to 6000. After that it pulls like a mother ******. But I am getting a new ECU tomorrow with Hondata and obd2-obd1. I hope this helps you.
Old Nov 21, 2005 | 10:52 PM
ITB
Guest
Posts: n/a
dude maybe its just a coincedence that it bogs when vtec kicks. you sound like a newbie are you shure you even know when vtec kicks. its a timing or spark issue
Old Nov 22, 2005 | 12:47 PM
dtm03's Avatar
Default Re: (ITB)
who was that directed towards?
Old Nov 22, 2005 | 02:28 PM
jizno's Avatar
Default Re: (ITB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITB &raquo;</TD></TR><TR><TD CLASS="quote">dude maybe its just a coincedence that it bogs when vtec kicks. you sound like a newbie are you shure you even know when vtec kicks. its a timing or spark issue</TD></TR></TABLE>
dont go dissin him about being new, your not exactly a life long member yourself.
Old Nov 24, 2005 | 01:44 PM
xtegb16x's Avatar
Default Re: (dtm03)
well i still have this problemm guys and i have changed everything possible from rotor to spark plugs.wires etc i got the oil change too buutt about the timing!! my timing belt snapped a while back and i got a new one and i got it put on perfectly and when i got it out of the shop that shti ****d in hard but can it jump a tooth i dont know if it can but yea thanx!!!! and for that dumass that thinks i dont know when vtec kiks in ur a dumshit ur the damn newbie and ur suppose to help out not hate n talk ****
Patch
Jan 3, 2020 06:55 PM
FrontwheelENT
14
Aug 20, 2012 05:30 AM
BLU CIVIC
Dec 4, 2008 04:41 AM
jbell
Mar 5, 2006 06:34 PM
fuck honda-tech
Dec 4, 2003 09:16 AM
