DC2 Door Panel Removal
Old Nov 20, 2005 | 12:10 AM
import810's Avatar
Default DC2 Door Panel Removal
I already searched for this and the ek 1 was no help so im starting this. I have read the service manual and I have no clue what they mean. I took out the inner door handle trim. The little plastic pocket thingy and 1 screw from the upper right side of the panel, but I can not fin the other 8 as featured in the service manual. If you could give me instructions that would be great, and If you give me pictures that would be hella awesome.
Old Nov 20, 2005 | 12:33 AM
brad.'s Avatar
Default Re: DC2 Door Panel Removal (import810)
Get your fingers under the bottom of the door panel and just pull. Continue around the door panel until you reach the top. Then, just push the panel up over the door frame, and you're done.
Don't forget to unplug the window switch harness and tweeters...unless you don't want them to "tweet" anymore.
Old Nov 20, 2005 | 01:02 AM
import810's Avatar
Default Re: DC2 Door Panel Removal ([626]96.GSR)
do i simply pop the tweeters out or is there screws???
Old Nov 20, 2005 | 02:03 AM
brad.'s Avatar
well, if you plan on removing the tweeters, there are screws.
Old Nov 20, 2005 | 02:32 AM
import810's Avatar
well i dont want to ruin anything
Old Nov 20, 2005 | 03:55 AM
Monkey Z.'s Avatar
you have to unplug them from behind the door panel
USDM DC4
May 19, 2007 06:19 PM
nathchong
10
May 5, 2007 12:46 PM
tchen415
Dec 1, 2006 09:44 PM
ThaSpitefulWun
Nov 7, 2003 05:55 AM
Daemione
Aug 8, 2001 12:18 PM
