overheating?
ok, i still need to check it but since im already here i wanted to ask about the temp. reading hot. either theres not enough fluid, one of the fans is not working, theres some kind of leak which builds up pressure or a sensor thing right? i think i noticed that it was dripping a little bit underneath. imma go check it out right now with my flash light to at least see if its low on fluid and try to see where it would be leaking out of. then tomm ill check to see if both fans are kickin in, but more than likely its that leak thats causing it to read hot right? i mean itll do it when im actually driving where cool air gets in, it doesnt have to be idiling for it to get hot.
ok i should be ok to drive a little bit right? i just put a little bit of water in it since it was a little low. so if it is bc of the leaking then would it be from pressure or from bein low on fluid? i plan on getting it fixed asap, but its not gonna hurt it if i drive only when i need to right
puffthomas
Sep 3, 2003 05:51 PM
