Check engine light help!
Old Nov 19, 2005 | 09:52 PM
alexb16hb's Avatar
Default Check engine light help!
I had a code 10 (IAT), so I replaced the iat sensor, let the negative battery cable off of the battery for 10 minutes and started the car up. Check engine light does not come on...great....but I wanted to just check. So I turned the car off and then I turned the car to the on postion and put the jumper wire in to check for codes. Now the CEL stays on constantly while the jumper is in and goes off when I take the jumper out. What is causing this? Thanks
Alex
Sorry for the long explanation just wanted to be exact!
Modified by alexb16hb at 2:19 AM 11/20/2005
Old Nov 19, 2005 | 10:19 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Check engine light help! (alexb16hb)
if there are no codes stored in the ECU then when you jump the connector the light will stay on ... you do not have a problem
alexb16hb's Avatar
reworded a little bit to further explain. Thanks
Alex
Old Nov 19, 2005 | 10:20 PM
alexb16hb's Avatar
oh sweet. I was thinking that if there are not any codes the light will not come on at all. Thanks
Alex
BettyBlue21
Jul 4, 2018 08:46 AM
dohmahklan714
Oct 21, 2006 08:43 PM
Project_EK
Aug 13, 2005 04:08 PM
redludevtec
Aug 15, 2004 04:00 PM
B18CR-X
Mar 27, 2004 06:38 AM
