Having the lower tie bar.. usage?
Old Nov 19, 2005 | 09:34 PM
7mile's Avatar
Default Having the lower tie bar.. usage?
what does this do? it looks nice, b ut i dont really know whats the usage?
Old Nov 21, 2005 | 10:49 AM
jdmcars.com's Avatar
Default Re: Having the lower tie bar.. usage? (7mile)
Pretty much the same as all tie-bars, just in a lower location. It ties together the suspension for less flex in the chassis under cornering. There are lower fronts and lower rears, and depending on how the car is originally set up from the factory (wish bone, etc) will depend on the effect of the bar being placed/installed.
Old Nov 21, 2005 | 11:51 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: Having the lower tie bar.. usage? (jdmcars.com)
the only way they can be used to there full potential is if you weld the brakets to the subframe so they do not move or flex when driving. BTW dont get any Spoon tie bars, had mine on for about 2 days before i bent them, with a 1.5inch drop.
Old Nov 21, 2005 | 12:18 PM
Big_Nate's Avatar
Minor bit of advice... you might want to try loosening the lca bolts where the bar attaches before you buy it. If you get the bar then find out the bolts are seized, you're in for a world of frustration. Just a thought
Old Nov 21, 2005 | 12:54 PM
b18c195's Avatar
its a waste of money dont get it...
lived dreams
Mar 11, 2009 07:21 PM
AllSpedup04
Sep 27, 2005 12:24 PM
gaydm
Dec 21, 2004 12:50 PM
Suave99
Sep 3, 2002 07:09 AM
