Skunk2 Camber kit isnt doing its job!
Old Nov 19, 2005 | 05:53 PM
jdmomar's Avatar
Default Skunk2 Camber kit isnt doing its job!
I just finished installing my front camber kit and I adjusted the ball joint all the way out on both sides. And now the car has straightned out but its still not straight. I noticed the diference right away but its still a little messed up. Has this ever happened to anyone? What did you do? Does anyone know why this could be happening? Any help appreciated....Thanks.
Old Nov 19, 2005 | 06:00 PM
Anthony's Avatar
Mr. Fuch-yu
Default Re: Skunk2 Camber kit isnt doing its job! (jdmomar)
I had this same problem when I first installed mine. My situation was fixed by just raising the car back up and sliding the balljoint all the way out again. What had happened was when I lowered the car down, the baljoint moved. Just raise it back up, slide it all the way out, and tighten it down tightly. Also, my steering wheel was crooked once I lowered my car. This was fixed 2 days later when some DICKWEED in a lincoln towncar pulled out in front of me. The shop had to send the car for an alignment and that took care of the steering wheel. Hope this helps.
-Red
Old Nov 20, 2005 | 08:43 PM
jdmomar's Avatar
Default Re: Skunk2 Camber kit isnt doing its job! (nitrared)
Thanks! It helped alot because thats exactly what happened. i just finished fixing it.
Old Nov 22, 2005 | 10:55 AM
Anthony's Avatar
Mr. Fuch-yu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmomar &raquo;</TD></TR><TR><TD CLASS="quote">Thanks! It helped alot because thats exactly what happened. i just finished fixing it. </TD></TR></TABLE>
No problem . Glad I could help.
-Red
Old Nov 22, 2005 | 11:01 AM
Mr. Wonderful's Avatar
what do you do?? you go get a damn alignment. every time you expletive with you suspension you're inadvertently adjusting you toe(which makes your car drive straight)
Old Nov 22, 2005 | 11:04 AM
spoonracer84eg's Avatar
Good info Im going to get mine adjusted tomorrow.
Old Nov 22, 2005 | 07:31 PM
Anthony's Avatar
Mr. Fuch-yu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Wonderful &raquo;</TD></TR><TR><TD CLASS="quote">what do you do?? you go get a damn alignment. every time you expletive with you suspension you're inadvertently adjusting you toe(which makes your car drive straight)</TD></TR></TABLE> Dude, no need to get hateful. He has never done this before. I give the dude props for doin the **** himself.
-Red
Old Nov 22, 2005 | 07:38 PM
neutron91's Avatar
Default Re: Skunk2 Camber kit isnt doing its job! (Mr. Wonderful)
yeah go get an alignment... dont even bother trying to fix that problem on your own you will never get it right
Old Nov 23, 2005 | 01:31 AM
Default Re: Skunk2 Camber kit isnt doing its job! (neutron91)
not being hateful. i did it myself too. then i got an alignment.
Old Nov 23, 2005 | 06:48 AM
Anthony's Avatar
Mr. Fuch-yu
Word. It just could've been taken as hateful. Props to everyone who does their own ****.
-Red
Nighthawk R18
Honda Civic (2006 - 2015)
21
Apr 17, 2009 10:58 AM
steveteggy92
Aug 16, 2008 03:57 PM
leeharveyoswald
May 22, 2007 07:40 PM
aandrewcc
Suspension & Brakes
10
Apr 4, 2006 11:14 AM
vteg
May 22, 2002 06:17 PM
