Car pulling to the right when braking hard >>
Old Nov 19, 2005 | 02:29 PM
platinum00's Avatar
Default Car pulling to the right when braking hard >>
car is pulling to the right when braking hard, or breaking over 90MPH.
new brakes, rotors, and rear disk swap.
i just did an alignment so it's not that.
is there a way to test the pressure in the line at each wheel. it feels like the front passenger side wheel is biting harder...
platinum.
Old Nov 19, 2005 | 02:56 PM
my_slow_civic's Avatar
Default Re: Car pulling to the right when braking hard >> (platinum00)
It's not uncommon for one brake caliper to become dirty, and grimy, and not clamp as hard.
Old Nov 19, 2005 | 03:03 PM
5thGenCivicKid's Avatar
slide pin on top of cailper might be frozen if... u wasnt greased
Old Nov 19, 2005 | 03:07 PM
EJ7's Avatar
EJ7
Bleed brakes again, only takes a coupla minutes, could save you alot of time
Old Nov 19, 2005 | 04:59 PM
EG2Driver's Avatar
Default Re: Car pulling to the right when braking hard >> (EJ7)
mine had the right brake pull....bled it and now all guud. Bleed
Old Nov 20, 2005 | 06:58 AM
platinum00's Avatar
Default Re: Car pulling to the right when braking hard >> (deadend9009)
thanks for the input.
i will try to bleed them again, and if that does not work i will re-greese...
im still using the stock EX Prop valve and master cylander. would that have anything to do with it. i thought this was only to fix loose pedal feel.
thanks again
platinum.
curtie94
Mar 19, 2012 03:27 AM
wolve
Suspension & Brakes
Mar 1, 2011 11:27 PM
t_mac
Jan 18, 2009 07:36 AM
em2ssm02
Dec 19, 2006 05:43 PM
Arvid
13
Aug 4, 2004 03:34 PM
