so i was taking apart my drum brakes... and then I decided not to go through with replacing shoes and drum. (still some life in them) anyways after a lot of struggling and some leaked brake fluid I got it back together properly. Anyways when I was doing it, I had a helper push the brakes on to pop out the rubbers on the wheel cylinder i was putting back together. Anyways I got it back together and thought well since I leaked out some oil. I should add more. I filled it up to the max line and applied the brakes slowly, then pumped them a few times. I find out that the wheel cylinder I had not been working on's rubbers have popped off so I put them back on pushed on the brake to make sure they stayed. I did manage to get the rubbers to stay on. the side I had taken apart- the drum went back on no problems. The other side which had not been dissaembled- the drum won't go back on. So I rolled the star wheel back al the way- the drum still doesn't go back on!! Now I don't know what to do... do I bleed the brakes? I can't see why this would help.. please experts. I need your help!!!! I'm losing confidence!!
*sigh*
*sigh*
Re: ****!
thats the thing I turned the adjuster all the way back. ie. its shorter then it was previously. Do I have to make it longer??? or do you think bleeding the brake lines would help?
Re: ****!
no. bleeding the brakes wont do jack ****.
go to autozone and get one of those "drum brake calibrator" tells you exactly where the pads should be adjusted to for maximum braking
dwllama
06-08-2017 02:23 AM
projekthonda02
Suspension & Brakes
04-15-2012 03:13 PM
mdmitch2
07-10-2005 08:46 PM
