97 civc with 2001 gsr swap...PLEASE HELP!!!!!
Old Nov 19, 2005 | 01:39 PM
teamvirus's Avatar
My car breaks a lot!
Default 97 civc with 2001 gsr swap...PLEASE HELP!!!!!
I'm doing a 2001 gsr swap into my 97 civic ex 5spd, and I had some questions.
What mounts do I need? I heard all I need is the rear mount from a 99-00 si. Also is there gonna be any problems with the ecu wiring, since the plugs are different. I heard I need to use the stock ex 5spd harness with the p72 ecu, any truth in that?
Someone also told me the 2001 gsr came with a key sensor or disabler?? Is there any way to get around that? thanks so much
Old Nov 19, 2005 | 01:40 PM
Archidictus's Avatar
Unceasing Measure
Default Re: 97 civc with 2001 gsr swap...PLEASE HELP!!!!! (teamvirus)
Search. That's what it's there for.
Old Nov 19, 2005 | 01:50 PM
kyden's Avatar
you will need:
si drivers side mount bracket
b series front tranny bracket
96-98 ex wiring harness
96-99 p72 or obd1, whatever you choose
Old Nov 20, 2005 | 03:56 AM
teamvirus's Avatar
Default Re: 97 civc with 2001 gsr swap...PLEASE HELP!!!!! (kyden)
bump
could i use a obd2a ecu p72 from a 98 integra? will it work with the civic ex harness?
Old Nov 20, 2005 | 05:03 AM
redhatch8u-up's Avatar
99-00 si rear mount conversion harness if going with obd1 but yeah there should be like a thousand posts for stuff like this if you look.
Old Nov 20, 2005 | 11:50 AM
teamvirus's Avatar
Default Re: 97 civc with 2001 gsr swap...PLEASE HELP!!!!! (redhatch8u-up)
bump
Old Nov 21, 2005 | 12:15 AM
teamvirus's Avatar
bump
Old Nov 21, 2005 | 09:16 AM
black_EM1's Avatar
Community Builder
Community Influencer
https://honda-tech.com/zerosearch
bodydropranger
May 28, 2003 08:21 PM
