Tips For B16A
I'm quite new with B16A engine and not really familiar with VTEC itself. Could anyone give me a tips/advise on how to maintain/handle the engine interm of the maintenance (oil, timing belt. air filter) Plus I'm also quite confused with the VTEC function which I don't know in what RPM the VTEC will fully function for B16A. Some said between 7000-8000, but some said it should be lower. What is the exact RPM for its original ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuned2 »</TD></TR><TR><TD CLASS="quote">are you running the B16 ecu. usually stock b16 vtec kicks in at about 4800. as for scheduled maintnece, search it.....</TD></TR></TABLE>
actually its 5500
actually its 5500
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">actually its 5500</TD></TR></TABLE>
actually it's 5875
actually it's 5875
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">
actually it's 5875</TD></TR></TABLE>
actually your wrong
actually your wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmB16Eg6 »</TD></TR><TR><TD CLASS="quote">
actually your wrong</TD></TR></TABLE>
seriously, change your avatar before i ban you
as for tips for maintaining the motor....change your oil every 3k or earlier if your going to romp it more then normal. I would just do a visual inspection every time you change your oil on the air filter and just check to make sure its clean.
as for Vtec i always thought it kicked at 5800...atleast thats what it says exactly on my vafc..but i have a type r ecu so who knows...
I'm 100% sure it's 5500 rpm, especially after owning a b16a2 with a CAI, you can hear it switch without straining to do so.
Oil changes - every 3000 miles or 3 months, which ever comes first.
Timing belt change - every 60k miles. I ran my original to 69k with no problems, but I was paranoid as ****.
Air filter - check it every few months, if it starts to get dirty replace it. I have a cone CAI on mine, I haven't checked it in over a year. Need to do that.
hondaon18's
43
Oct 7, 2007 12:56 PM
