MSD boost timing retard
Got this with the turbo kit. Not going to use it as i am getting uberdata or Hondata.
http://www.msdignition.com/tc_18.htm
Universal Boost Timing Master
The Universal Boost Timing Master allows you to adjust the ignition timing in relation to the boost pressure plus it has a built-in inductive ignition. You can adjust the dash mounted control **** to retard the timing 1° - 3° per pound of boost, up to 20°. The increased spark output of the BTM helps burn the fuel mixture more efficiently resulting in more power - a definite advantage when boost pressure is increasing. The Universal BTM is designed to work with most single coil factory or aftermarket ignition amplifiers and points type distributors.
Master (non MSD Ignitions)
PN 5462
Located in Canada... buyer pays shipping and fees
open to offers... need this gone
PN 5462
