Removing Spoiler on DC2
Old Nov 18, 2005 | 03:18 PM
beevo.'s Avatar
Default Removing Spoiler on DC2
What are good ideas for plugging the holes on the hatch when removing the oem spoiler? If you have done this before then help me out. Thanks.
Old Nov 18, 2005 | 03:33 PM
Circuit Star-29's Avatar
Default Re: Removing Spoiler on DC2 (GoldenDC2)
You can try to find some rubber plugs at a local hardware store. Bondo, bolts n washers, and tape are the quick fixes.
Old Nov 18, 2005 | 03:40 PM
Dogginator's Avatar
Daisy... Daisy...
You will need to do body work and paint for the wire harness (passenger ~1" diameter) and plastic stud (driver side ~1/2" diameter) holes. These will allow water to enter the hatch if they are not plugged.
You can see all six holes on the diagram
Old Nov 18, 2005 | 04:16 PM
rasinhell's Avatar
Default Re: Removing Spoiler on DC2 (Dogginator)
i've never done it before, and I dont know if the holes are accessable from the inside, but I think fiberglassing from the opposite side, and then filling from the top would be a good idea.
try http://www.autobody101.com in the forums and ask em. lots of intelligent autobody heads there.
Old Nov 18, 2005 | 04:18 PM
98 Spec R's Avatar
You could always look for someone that has the same color Integra without a spoiler and ask them to trade. You wont have to cover up the holes at all. My friend did this.
Old Nov 18, 2005 | 04:26 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Removing Spoiler on DC2 (plugg'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by plugg’d &raquo;</TD></TR><TR><TD CLASS="quote">i've never done it before, and I dont know if the holes are accessable from the inside, but I think fiberglassing from the opposite side, and then filling from the top would be a good idea.
try http://www.autobody101.com in the forums and ask em. lots of intelligent autobody heads there.</TD></TR></TABLE>
The holes are accessible once you remove the hatch trim. You can weld or epoxy a metal plate behind the hole. The surface is then filled with body putty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R &raquo;</TD></TR><TR><TD CLASS="quote">You could always look for someone that has the same color Integra without a spoiler and ask them to trade. You wont have to cover up the holes at all. My friend did this.</TD></TR></TABLE>
That is a great option if available.
Old Nov 18, 2005 | 06:13 PM
beevo.'s Avatar
I was thinking more along the lines of the rubber plugs, so if anyone has more info on those I am all ears. I will eventually get body work done, but my spoiler is scratched up right now + I like the wingless DC2 look. Thanks for all the replies.
Old Nov 18, 2005 | 06:49 PM
Vi3tboy's Avatar
go wingless and get it welded shut!
i love wingless dc's also
Old Nov 18, 2005 | 07:34 PM
beevo.'s Avatar
Clean car !!
I will eventually get it welded, but I will prolly plug them for now. So more info on where to buy the rubber plugs, I have seen many DC's with plugs so I know someone knows.
Old Nov 18, 2005 | 07:42 PM
rasinhell's Avatar
oh yeah.. i was just suggesting a more simple method as opposed to welding a metal plate to the back. w/ the fiberglass method, it would be easier for the untrained hands to accomplish that rather than welding.
another option is leading aka. body solder. it's usually used for adding lead to thinning metal, but i think it would work with the holes
Old Nov 18, 2005 | 07:53 PM
Sic_DA_Nine's Avatar
there are plugs in your engine bay..
where the type R strut bar suppose to bolt on to
topic ended
Modified by 97dC4 at 10:19 PM 11/18/2005
Old Nov 18, 2005 | 09:08 PM
Default Re: (97dC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dC4 &raquo;</TD></TR><TR><TD CLASS="quote">there are plugs in your engine bay..
where the type R strut bar suppose to bolt on to</TD></TR></TABLE>
Bingo
Old Nov 18, 2005 | 10:23 PM
Kito96LS's Avatar
Default Re: Removing Spoiler on DC2 (C-speed racer)
jus tape the holes up for now n get the wing fix..n get the holes filled n paint later on
Old Nov 18, 2005 | 10:26 PM
backroad-B18's Avatar
Before i painted my car I used a getto but efficent way to plug my wing holes.
Step One: use a strong adhesive (duct) tape and place under your holes.
Step Two: cover the holes with several layers of touch up paint and let dry.
It never leaked and looked clean from a distance.
Old Nov 18, 2005 | 10:39 PM
why do the tape way when i just told you guys where the plugs are...its not like you even have to buy them. its already on the car!
Old Nov 18, 2005 | 10:47 PM
Integra_drk's Avatar
Default Re: (97dC4)
he is right ^^^
Old Nov 18, 2005 | 10:56 PM
With the touch up paint over the tape made the holes look almost non existant
Old Nov 18, 2005 | 11:14 PM
Squrtin DC2's Avatar
Default Re: Removing Spoiler on DC2 (backroad-B18)
take it to a body shop and have them do it
Old Nov 18, 2005 | 11:18 PM
Alexander's Avatar
Default Re: Removing Spoiler on DC2 (Squitin DC2)
Wingless is just a fad.
Old Nov 19, 2005 | 04:56 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (97dC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dC4 &raquo;</TD></TR><TR><TD CLASS="quote">why do the tape way when i just told you guys where the plugs are...its not like you even have to buy them. its already on the car!</TD></TR></TABLE>
The plugs that you suggested will cover only four of the six holes. The ITRs can do this because the ITR spoiler does not have the LED brake light in the wing and the subsequent wiring harness.
Do you see the large hole for the wiring harness?
The geniuses at Honda placed these holes so other wings without LED brake lights (i.e. my Mugen SiR wing) do not cover these holes.
Old Nov 19, 2005 | 07:08 AM
Robstunner4's Avatar
Default Re: (Dogginator)
or you can find someone with a LS that didnt come with a spoiler and offer a trade.
Old Nov 19, 2005 | 05:41 PM
calxtreme's Avatar
I used electrical tape and paiinted with touch up paint. Tape is much flush than plugs.
odogg726
Nov 27, 2007 06:49 PM
tegda
Apr 30, 2007 12:39 PM
Cuong-nutz
17
Dec 24, 2004 09:21 PM
DC2 to AP2
Apr 20, 2004 06:02 PM
BANGBANG
Apr 1, 2004 07:46 AM
