Everyone thats installed a Aftermarket clutch..
Everyone thats installed a Aftermarket clutch can you tell me if you had to adjust the clutch pedal. I just got my new Spec Clutch installed. The first Spec clutch took a ****.
THIS IS HYPOTHETICALLY
I think the clutch pedal wasn't adjusted properly. And I know with Aftm. clutches the pedal gets shorter. Mine didn't... So possibley the clutch pedal had the stock travel disctance. Which caused the release bearing to push farther and harder on the Aftm. pressure plate. That could have caused the damge in my previous post. And that could have caused the first clutch to take a dump...
Previous Post With Pics: https://honda-tech.com/zerothread?id=1426938
Let me know if you guys had a shorter pedal stroke or if you manually adjusted it???
