2001 gsr motor in 94 dx hatch...what is needed to be bar'd??? HELP!!!
Okay, here's the deal. My smog is needed to be done by January and just got the 01 gsr swapped into the 94 dx hatch. Now, what I need to know is, what do I need to get the bar sticker? Here's my setup...
1.) 01 gsr with 01 engine harness (not chassis harness)
2.) 95 gsr ecu
3.) Pinned knock sensor, vtec, etc.
What worries me is that I've read that I have to convert my intake manifold, engine harness, and other pieces to obd1. Is that true? So, what is it that I really need to do to get a bar sticker? Need help!!! Tried searching, but most people have obd1 motor into obd1 car. Please Help!!! What do I need to do.
2.) 95 gsr ecu
i think you just need all the smog **** and sensors, pretty mucn have everything the same as if the motor was still in a 95 integra
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NsX_CrX »</TD></TR><TR><TD CLASS="quote">Okay, here's the deal. My smog is needed to be done by January and just got the 01 gsr swapped into the 94 dx hatch. Now, what I need to know is, what do I need to get the bar sticker? Here's my setup...
2.) 95 gsr ecu
What worries me is that I've read that I have to convert my intake manifold, engine harness, and other pieces to obd1. Is that true? So, what is it that I really need to do to get a bar sticker? Need help!!! Tried searching, but most people have obd1 motor into obd1 car. Please Help!!! What do I need to do.</TD></TR></TABLE>
Most likely you will fail the referee test because your car is obd 1 and the engine is obd2. In order to ref. the engine you must have all the smog sensors and hoses hooked up. You must used the 2001 ecu with the engine also. That one big reason you will fail.
2.) 95 gsr ecu
kajay1972
11
Sep 2, 2007 03:32 PM
Eg6_rAcEr
Oct 23, 2005 12:00 AM
