just rebuilt motor and car idles too high!!!
Old Nov 17, 2005 | 06:00 PM
nexepisode's Avatar
Default just rebuilt motor and car idles too high!!!
i just recently rebuilt my motor to a da6 integra, b16 pistons and p&p head, i start the car and it idles all the way to 2.5 rpm and the check engine light turns on, i thought it would be a vaccum leak but all hoses are secure, does anybody have any ideas what could be wrong with it? thanks in advance-*****
Old Nov 17, 2005 | 06:46 PM
nexepisode's Avatar
Default Re: just rebuilt motor and car idles too high!!! (nexepisode)
come on, need serious help, im not a diagnostic kinda guy.
Old Nov 17, 2005 | 07:54 PM
93EG6SI's Avatar
what code is it throwing?
Old Nov 17, 2005 | 08:28 PM
sitinthehall's Avatar
There is a little screw on the throttle body, turn it and the idle will go down.
Old Nov 19, 2005 | 01:40 AM
nexepisode's Avatar
thats the idle air control vavle right? i tried that before and it didnt seem to help, can it be a blown thermo sensor?
Old Nov 19, 2005 | 10:30 AM
mmuller's Avatar
Mad Scientist
Default Re: (nexepisode)
Whats the code its throwing?
Its prolly a vaccum leak. check your tb and intake manifold gaskets
Old Nov 20, 2005 | 06:24 AM
mad-ass's Avatar
reset your ECU.
check vaccume leak
all sensors check. especially the 02 and the TPS.
Old Nov 20, 2005 | 04:14 PM
bosco500's Avatar
have you adjusted the throttle?
Old Nov 21, 2005 | 04:50 AM
wamps97teg's Avatar
or maybe to throttle cable is too tight
Old Nov 21, 2005 | 07:29 AM
mad-ass's Avatar
Default Re: just rebuilt motor and car idles too high!!! (wamps97teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wamps97teg &raquo;</TD></TR><TR><TD CLASS="quote">or maybe to throttle cable is too tight
you mean short.
Old Nov 21, 2005 | 09:46 AM
BMcGinnis6's Avatar
try twisting the throttle body screw and if thats not it you might need new fuel injectors
Old Nov 21, 2005 | 10:25 AM
bosco500's Avatar
Default Re: just rebuilt motor and car idles too high!!! (BMcGinnis6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMcGinnis6 &raquo;</TD></TR><TR><TD CLASS="quote"> if thats not it you might need new fuel injectors</TD></TR></TABLE>
Why would he need fuel injectors? He has a high idle.
Old Nov 21, 2005 | 11:47 PM
mad-ass's Avatar
Default Re: just rebuilt motor and car idles too high!!! (bosco500)
unstable connection/injection perhaps?
Old Nov 22, 2005 | 04:45 AM
bosco500's Avatar
Default Re: just rebuilt motor and car idles too high!!! (mad-***)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mad-*** &raquo;</TD></TR><TR><TD CLASS="quote">unstable connection/injection perhaps?</TD></TR></TABLE>
A fuel injector problem cannot cause a high idle. You need more air to create a high idle. Too much fuel will make the mixture too rich and will kill the motor or make it run like hell.
Efjams24
Jul 22, 2012 02:00 PM
vteghatch
Aug 16, 2005 07:06 PM
1.8EG-T
10
Mar 26, 2003 10:04 AM
iwouldHITit
Mar 9, 2003 08:33 PM
