When doing b16a2 into a eg, will the 2000 si throttle cable fit?
Old Nov 17, 2005 | 11:08 AM
jadugartir's Avatar
Default When doing b16a2 into a eg, will the 2000 si throttle cable fit?
title says it all
Old Nov 17, 2005 | 12:24 PM
jadugartir's Avatar
Default Re: When doing b16a2 into a eg, will the 2000 si throttle cable fit? (jadugartir)
nobody knows? i already went and ordered it from the dealership, but i guess ill just leave it in the package in case i dont need it for the swap. Im pretty sure my EX one wont fit though.
Old Nov 17, 2005 | 01:34 PM
civichbcx's Avatar
You might want to try a 92-95 DelSol VTEC (DOHC) throttle cable....just a suggestion.
Old Nov 17, 2005 | 01:37 PM
dohcMONSTER's Avatar
ITR throttle cable
Old Nov 17, 2005 | 01:40 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: When doing b16a2 into a eg, will the 2000 si throttle cable fit? (dohcMONSTER)
if i remember, i have the 99-00 si cable on mine.
Old Nov 17, 2005 | 01:48 PM
civichbcx's Avatar
If you use the ITR throttle cable, do you also need the Type R throttle cable mounting bracket for it to work correctly??
Old Nov 17, 2005 | 01:55 PM
Mr. Badwrench
Default Re: When doing b16a2 into a eg, will the 2000 si throttle cable fit? (civichbcx)
the b16 and b15c5 use the same mounting point and should use the same bracket.
Old Nov 17, 2005 | 03:08 PM
AnDThEnWuT's Avatar
Default Re: When doing b16a2 into a eg, will the 2000 si throttle cable fit? (boostedcivicsir)
i used the same throttle cable that came with my DX, made my own mounting bracket, not the best looking one, but it works!
Old Nov 17, 2005 | 03:42 PM
cybergreencivic's Avatar
Default Re: When doing b16a2 into a eg, will the 2000 si throttle cable fit? (AnDThEnWuT)
same here
civic_loner22
Mar 15, 2011 03:51 PM
94allmotor
Feb 11, 2009 08:25 PM
HBP.EH2
Jun 11, 2005 09:13 PM
Art701
Aug 12, 2004 08:52 AM
Bnjmn
Dec 6, 2003 08:44 AM
