Wipers Popped Now Acting Up
Old Nov 17, 2005 | 02:46 AM
JimmyAtlantis's Avatar
Default Windshield wiper problem.
We got a shitload of snow on the south side of Buffalo overnight. I had my wipers going then I heard a loud pop. My wipers quit working. Now they're free swiping and don't go back all the way. What did I break?
Old Nov 17, 2005 | 02:52 AM
sicky's Avatar
grammer nawzi
Default Re: Windshield wiper problem. (JimmyAtlantis)
I had a similar problem a little while back, turned out that the bolt had just become loose. Might want to check the wiper bolt and see if the nut became loose, or what. not sure about some loud pop, hope you get it fixed.
Old Nov 17, 2005 | 03:13 AM
Default Re: Windshield wiper problem. (sicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar problem a little while back, turned out that the bolt had just become loose. Might want to check the wiper bolt and see if the nut became loose, or what. not sure about some loud pop, hope you get it fixed.</TD></TR></TABLE>
It's not that because they're both like that and if you move one they both move. So they're definately still tied in to each other through the motor.
Old Nov 17, 2005 | 05:08 AM
TTT. Don't want to have to go to a garage if this is something I can fix myself.
Old Nov 17, 2005 | 05:40 AM
Do you need to remove the dash to install a new wiper motor?
Old Nov 17, 2005 | 08:40 AM
Up.
Old Nov 17, 2005 | 09:45 AM
There are people here that can build engines. I know somebody can help me with this.
Old Nov 17, 2005 | 11:31 AM
Up again.
Old Nov 17, 2005 | 12:46 PM
Relic1's Avatar
the arms are tied together through the linkage.
it's been a while since I've looked at it but I think there is another bolt that connects the linkage to the motor.
pull off the shrouding around the wipers and take a look.
Old Nov 17, 2005 | 05:26 PM
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">the arms are tied together through the linkage.
pull off the shrouding around the wipers and take a look.</TD></TR></TABLE>
I talked to a man at a garage today and he said the same thing. I looked on hondaautomotiveparts.com and I can't pinpoint it. I know these diagrams are shitty, but looking at it, what number would you think the culprit may be?
http://www.hondaautomotivepart...BA%29
Old Nov 17, 2005 | 06:11 PM
dropcivic's Avatar
Default Re: (JimmyAtlantis)
12 and 13, the wiper arm linkage. They go bad all the time on civics and accords. Pop off the windsheild crowl piece and see if one of the linkages has come off. #12 connects to the motor so that should be the one that is off. They are real easy to put back on, just put the cap over the peg in the motor and press down on it while moving the arm side to side.
Old Nov 17, 2005 | 06:38 PM
siblueg's Avatar
see if the thread is stripped
Old Nov 18, 2005 | 01:55 AM
Default Re: (dropcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dropcivic &raquo;</TD></TR><TR><TD CLASS="quote">12 and 13, the wiper arm linkage. They go bad all the time on civics and accords. Pop off the windsheild crowl piece and see if one of the linkages has come off. #12 connects to the motor so that should be the one that is off. They are real easy to put back on, just put the cap over the peg in the motor and press down on it while moving the arm side to side.</TD></TR></TABLE>
Then I'm going with #12 since the wipers are still connected to each other. Thanks.
MakeshiftJPN
May 11, 2012 03:03 AM
sonny0330
May 29, 2008 06:53 AM
HCJDM1
Feb 2, 2007 06:09 PM
Muckman
Jun 8, 2006 04:42 PM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
