Help please...cooling fan acting up!!!
Old Nov 16, 2005 | 07:43 PM
hnp5's Avatar
Default Help please...cooling fan acting up!!!
whats goin on guys....i have this little problem....i had my car sold but it so happens that it started raining today like crazy, i was driving my car and i kinda like hit a puddle of water so i keep driving cause i wasnt goin fast. my boy looks at the temperature and im overheating, so i stop and pull over let it cool down...i just replaced the thermostat...the fuse to the cooling fan is not popped. also whenit over heated the fan wasnt turning on and the reserve tank was full with antifreeze and last but not least the cap to the reserve tank was loose....any ideas??? i need help please...thanx
Old Nov 16, 2005 | 07:51 PM
The_Todd's Avatar
Farts in the shower
Default Re: Help please...cooling fan acting up!!! (cuban0)
When you replaced the thermostat did you bleed the cooling system? Does the fan turn on? Did you fill the cooling system with enough coolant?
More info needed.
Old Nov 16, 2005 | 07:53 PM
hnp5's Avatar
Default Re: Help please...cooling fan acting up!!! (.ken)
when i replaced the thermostat i didnt bleed the system, i was in a hurry which was stupid of me. and yes the fan was turning on then....now is not
Old Nov 16, 2005 | 07:59 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cuban0 &raquo;</TD></TR><TR><TD CLASS="quote">when i replaced the thermostat i didnt bleed the system, i was in a hurry which was stupid of me. and yes the fan was turning on then....now is not</TD></TR></TABLE>
Bleed the system, should fix your problem.
Old Nov 16, 2005 | 08:01 PM
hnp5's Avatar
and by the way, it did have enough coolant...i think...i had to run a wire to the positive on the battery to turn the fan...and it worked fine...but why isnt the fan turning on?
Old Nov 16, 2005 | 08:09 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cuban0 &raquo;</TD></TR><TR><TD CLASS="quote">and by the way, it did have enough coolant...i think...i had to run a wire to the positive on the battery to turn the fan...and it worked fine...but why isnt the fan turning on?</TD></TR></TABLE>
You said the fan was working ok...but by bypassing the fan temp sensor it should turn on if the fan is good. I would bleed the system and see if the fan turns on, if it doesn't you may have to replace your fan temp sensor. Read this thread for great info:
https://honda-tech.com/zerothread?id=1319899
and
https://honda-tech.com/zerothread?id=1424191 &lt;===very good how-to .
Old Nov 16, 2005 | 08:11 PM
hnp5's Avatar
appreciated...thanx a lot
Blaze45
Mar 8, 2018 02:57 PM
walrus_07
Feb 21, 2009 10:16 PM
elnoyl
Aug 18, 2006 06:24 PM
ek9si
Jun 18, 2003 04:42 AM
REDBARON
13
Nov 28, 2001 11:38 AM
