Hondata+J&S? compatability ?'s
Old Mar 11, 2002 | 05:13 PM
BlackOutSi's Avatar
Default Hondata+J&S? compatability ?'s
Just wondering... since the Hondata has its own boost retard, and the J&S has boost retard, will they mess each other up? And it has it's own map sensor, but the Hondata has an optional 3 bar map as well.. Do you just tap in the J&S on top of the Hondata/factory wiring?
I'm getting Hondata 3b, but I won't have a knock sensor. I was just planning on running the J&S unit to control the knock (if I get any)........
Old Mar 11, 2002 | 05:17 PM
shawnhayes's Avatar
Default Re: Hondata+J&S? compatability ?'s (BlackOutSi)
Why won't you have a knock sensor?
Shawn
Old Mar 11, 2002 | 05:24 PM
BlackOutSi's Avatar
Default Re: Hondata+J&S? compatability ?'s (shawnhayes)
The Hondata requires an OBD-1 ECU, and the one I'll be using will have the knock sensor disabled. All according to Hondata's website. I don't like this considering not having a knock sensor probably blew up my motor...
Old Mar 11, 2002 | 06:04 PM
Mike M's Avatar
Founding Member
I have both and no problems
Old Mar 13, 2002 | 03:36 AM
shawnhayes's Avatar
Why don't you get one with a knock sensor? I don't seem to understand.
Shawn
Old Mar 13, 2002 | 10:08 AM
Austin's Avatar
Default Re: Hondata+J&S? compatability ?'s (Evil TypeRmsm)
So do I...just purchase the J&S Safeguard Version 0, as you wont have a need for the boost retard feature since Hondata has the maps for you. I highly recommend using the J&S & a P28 over a P72 by itself...J&S is far beyond the stock program of the P72 knock retard.
Austin
shreddinryguy
May 12, 2005 10:53 PM
SuperImport
Apr 12, 2005 05:55 PM
BoostedGSRBubble
Jan 17, 2003 10:27 PM
B18Flip
Oct 28, 2002 05:53 PM
93B18
Feb 3, 2002 12:32 AM
