Oil level - hot or cold?
Old Nov 16, 2005 | 04:10 PM
davidluko's Avatar
Default Oil level - hot or cold?
So are you supposed to check your engine oil level when it's warm or cold? If warm, how long do you let it stand before checking it? I poured oil in to the correct level when it was warm but then I checked it when cold and it was above the top hole. What does it do if it's a little above the top hole (like 3 mm maybe)?
Old Nov 16, 2005 | 04:41 PM
Abadge4Life's Avatar
Default Re: Oil level - hot or cold? (Hatch_R)
Check it cold when the oil's in the pan.
Old Nov 16, 2005 | 05:42 PM
Backk InTheDA's Avatar
I hate everything
Default Re: Oil level - hot or cold? (Abadge4Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Abadge4Life &raquo;</TD></TR><TR><TD CLASS="quote">Check it cold when the oil's in the pan.</TD></TR></TABLE>
Yeah check it when it is cold. What can happen if there is too much oil in your engine, im not sure how far it has to be above the top dot, but 3mm should be OK. What can happen, I believe that it will put too much pressure on your gaskets/seals and blow them.
Old Nov 16, 2005 | 05:58 PM
Johnny_Rocket's Avatar
Default Re: Oil level - hot or cold? (BuilttB18C5)
it will slosh around in the pan too much and also it creates pressure where you don't want any causing **** to leak... simply put it's not a good idea. I would take some out
Old Nov 16, 2005 | 06:09 PM
96dc2's Avatar
Default Re: Oil level - hot or cold? (JohnnyH)
DEAD cold, usually in the mornings, on LEVEL ground.
Old Nov 16, 2005 | 06:25 PM
98GSRrdr's Avatar
Default Re: Oil level - hot or cold? (96dc2)
Yea , COLD works best , the reason ? cuz all the oil was settled to the bottom If you start it and then check alot of oil wont just be sitting in your oilpan , kinda makes sense
Old Nov 16, 2005 | 07:26 PM
93_teg_CT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dc2 &raquo;</TD></TR><TR><TD CLASS="quote">DEAD cold, usually in the mornings, on LEVEL ground.</TD></TR></TABLE>
Old Nov 16, 2005 | 07:30 PM
numotive's Avatar
Default Re: Oil level - hot or cold? (93_teg_CT)
wow thats news to me, i thought you always check it when its warmed up....
Old Nov 17, 2005 | 12:30 AM
-Todd-'s Avatar
Default Re: Oil level - hot or cold? (vtecriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecriver &raquo;</TD></TR><TR><TD CLASS="quote">checking oil is overated thats what you have an oil light for, or if you have a gsr or itr and vtec wont cross over or it kinda sputters when it trys to cross over you know your low!</TD></TR></TABLE>
lol I hope you're joking.
Old Nov 17, 2005 | 06:36 AM
Rory Breaker's Avatar
Someone better put this in their sig before I do!!!
Old Nov 17, 2005 | 10:36 AM
davidluko's Avatar
The reason I asked about the cold vs. hot is because when cold it's all sitting in the oil pan but then other people say to do it when hot because the oil expands. Well I guess I'll drain it then, I don't know why my dad told me to add more considering he used to be a mechanic and worked on cars for a lnng time.
Old Nov 17, 2005 | 01:45 PM
numotive's Avatar
Default Re: (Hatch_R)
just remember you gotta take alot of what people say on here with a grain of salt. theres alot of people on here who think they know alot about cars that love to stand up on their box so they can preach any chance they get.
motegicivic
Oct 13, 2011 05:59 PM
ZygSpeed
Mar 15, 2005 02:06 PM
Qwikrex
Dec 11, 2002 03:05 PM
JMinSi2000
Aug 15, 2002 07:49 PM
Blue teg
Dec 4, 2001 06:07 AM
