H-Braces? do they work?
Old Nov 16, 2005 | 09:12 AM
J Rob's Avatar
* B A N N E D *
Default H-Braces? do they work?
i was looking on ebay for some strut bars / ties bars to stiffern up my car and i noticed something ive never seen, h-braces. Do these actually work and where do they mount?
Old Nov 16, 2005 | 09:15 AM
Turbo_y8's Avatar
Default Re: H-Braces? do they work? (Its A Honda Thing)
yes they work, stiffen the front up, its like a lower tie bar, the front of the h brace, with the circles bolt in to your front lca's and then the rear bolt into the frame by your cat
Old Nov 16, 2005 | 09:17 AM
J Rob's Avatar
* B A N N E D *
Default Re: H-Braces? do they work? (tuck'd98)
is it a good investment if im buying strut bars and tie bars?
Old Nov 16, 2005 | 09:20 AM
Turbo_y8's Avatar
yea, dont get the front lower tie bar however if you are gunna run an h brace, im running a mugen front upper tie bar, h brace, rear upper tie bar, and rear lower tie bar, handles nice but the next thing im gunna do is a rear sway bar
Old Nov 16, 2005 | 09:39 AM
Relic1's Avatar
if you're going to get a H-brace don't get the one with the rear bar support. like this...
http://cgi.ebay.com/ebaymotors...81562
the second brace will more than likely hit your exhaust.
one like this will be fine.
http://cgi.ebay.com/ebaymotors...25076
Old Nov 16, 2005 | 09:45 AM
Turbo_y8's Avatar
Default Re: (Relic1)
my second brace is aboutan inch and half fromt he exhaust pipe
Old Nov 16, 2005 | 10:37 AM
Relic1's Avatar
strange... my second h-brace had that second bar, I had to remove it to even install the thing. my exhaust runs about 1 inch below the first bar, and right in between the points where the second bar was.
might be an EK/EG thing.
Old Nov 16, 2005 | 11:07 AM
Turbo_y8's Avatar
possibly, i actaully cut inch out of mine to hung the chassis more and had to grind slightly on the inside for a lil exhaust clearance but no rubbing now and it hugs the chassis nicely
Old Nov 16, 2005 | 12:00 PM
Relic1's Avatar
Default Re: (tuck'd98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">possibly, i actaully cut inch out of mine to hung the chassis more and had to grind slightly on the inside for a lil exhaust clearance but no rubbing now and it hugs the chassis nicely</TD></TR></TABLE>
I have a few questions unrelated to the bar, so to prevent thread jacking, tuck’d98 you have IM
Old Nov 17, 2005 | 01:11 PM
J Rob's Avatar
* B A N N E D *
i already bought a front lower tie bar is it worth the $60+ to get the h brace?
Old Nov 17, 2005 | 01:15 PM
Turbo_y8's Avatar
i noticed the h brace did more than the lower tie bar
Redis_323
Mar 10, 2013 12:43 AM
spens 91 Ef
Oct 27, 2008 02:27 PM
OnePointFive
Aug 29, 2006 12:06 PM
SB97civic
29
Feb 15, 2004 12:46 PM
kefka
Nov 26, 2001 10:11 PM
