Will my motor be ok?!?
Old Nov 15, 2005 | 09:29 PM
vc's Avatar
vc
Modified by vc at 9:40 PM 3/5/2006
Old Nov 15, 2005 | 09:31 PM
Chong's Avatar
ballin
Default Re: Will my motor be ok?!? (vc)
Should be...
Old Nov 15, 2005 | 09:37 PM
Chong's Avatar
ballin
Does it seem any different than it used to be? Im pretty sure the GSR can handle 9k once in a blue moon.
Old Nov 15, 2005 | 09:46 PM
VRD^sam's Avatar
Default Re: Will my motor be ok?!? (Chong)
should be fine but you never now...aslong as you don't do it all the time...
Old Nov 15, 2005 | 09:54 PM
Chong's Avatar
ballin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vc &raquo;</TD></TR><TR><TD CLASS="quote">
Its my first time. damn that was the longest 15secs of my life.</TD></TR></TABLE>
15 secs?
Old Nov 15, 2005 | 09:59 PM
Siberian Husky's Avatar
15seconds?..you mean the entire situation with your downshift..or 15 seconds of worrying after you did it?.cause if you had a led foot for 15 seconds with the gas pedal down and the rpms to 9000...then you must have a horrible reaction time and shouldnt be driving in the first place..people will flame..so edit your shiznit or clarify your post..
Old Nov 15, 2005 | 10:23 PM
NerveAgent's Avatar
you should still be ok.
Old Nov 15, 2005 | 10:30 PM
The_Todd's Avatar
Farts in the shower
Should be ok. But a suggestion since you have a p28, why don't you set fuel cut off/redline to a specified level so you don't do it again .
Old Nov 15, 2005 | 10:38 PM
slo97coupe's Avatar
ahh itll be fine!!! if my d16y7 can be ragged out to 7500 rpms your b18 will make it LOL....d16 is 2 inchex from death but still running strong!!!
Old Nov 15, 2005 | 11:38 PM
gapergurlie_18's Avatar
ive done 9000 to 9300 im my gsr... ull be fine
Old Nov 16, 2005 | 12:45 AM
Eaglekper0046's Avatar
I wouldn't worry ive done 9600-9700 in my stock b16 several times. and the gsr is stronger.
Old Nov 16, 2005 | 01:06 AM
yeh thats true but 600-700 rpms is alot the gsr has alot stonger bottom end if your motor is running fine and theirs no odd noises when why worry?
Old Nov 16, 2005 | 01:19 AM
b18civicguy's Avatar
Default Re: Will my motor be ok?!? (Eaglekper0046)
The general rule is that if it didn't already go pop right there and then... you'll be alright. The standard valvetrain in my experience can easily withstand 9000rpm every so often.
Old Nov 16, 2005 | 01:25 AM
O16581724 5 2 5's Avatar
Default Re: Will my motor be ok?!? (b18civicguy)
I went from about 70 in 5th to 2nd insted of 4th trying to pass, i floored it and felt like i hit the brakes insted of the gas, the tach pegged, no problems with it.
Old Nov 16, 2005 | 01:29 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Will my motor be ok?!? (O16581724 5 2 5)
If your motor still runs, your fine.
Old Nov 18, 2005 | 08:10 PM
Default Re: Will my motor be ok?!? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">If your motor still runs, your fine.</TD></TR></TABLE>
Yup, the main risk of doing that is floating a valve, you'll know immediately if that happens.
Old Nov 18, 2005 | 09:31 PM
peacexisxfree's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 &raquo;</TD></TR><TR><TD CLASS="quote">I went from about 70 in 5th to 2nd insted of 4th trying to pass, i floored it and felt like i hit the brakes insted of the gas, the tach pegged, no problems with it.</TD></TR></TABLE>
holy ****...i bet that got your heart beating.
Old Nov 18, 2005 | 09:32 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chong &raquo;</TD></TR><TR><TD CLASS="quote">Does it seem any different than it used to be? Im pretty sure the GSR can handle 9k once in a blue moon.</TD></TR></TABLE>
Exactly, it should be able to handle it if you don't beat on it daily. As long as you drive it well and keep it well maintained, you should be fine. Does anything sound/feel/drive different?
Old Nov 20, 2005 | 08:27 PM
cambopheonix56's Avatar
Psshht, my friend was shiftin from 3rd gear at 8k and mis0shifted to 2nd, it went waaaaayyyyy past the 9500 rpm where teh red stops. Probably 11k or more. His motor is fine.
Old Nov 20, 2005 | 08:28 PM
.Ry's Avatar
.Ry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 &raquo;</TD></TR><TR><TD CLASS="quote">I went from about 70 in 5th to 2nd insted of 4th trying to pass, i floored it and felt like i hit the brakes insted of the gas, the tach pegged, no problems with it.</TD></TR></TABLE> He was talking about this guy lol...still runnin good?
Old Nov 20, 2005 | 08:48 PM
Kamin's Avatar
Default Re: Will my motor be ok?!? (.ken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">Should be ok. But a suggestion since you have a p28, why don't you set fuel cut off/redline to a specified level so you don't do it again .</TD></TR></TABLE>
this is called a mechanical overrev.
there is NO protection against it.
the wheels are driving the engine. not the throttle.
Old Nov 20, 2005 | 11:31 PM
civiccoupe94's Avatar
i mishifted before in my b7 dx motor, and went to 8,200 or so, and its fine. bone stock dx. so 9k on a gsr should be ok
HYREV2NR
Audio / Security / Video
15
Oct 15, 2008 07:46 AM
vodkas22
Paint and Body
May 27, 2007 09:31 PM
baybee_boy
Jul 26, 2005 03:01 PM
C-Zero
Welding / Fabrication
16
Aug 30, 2004 09:53 PM
