Those of you with a b18b in an eg...
Old Nov 15, 2005 | 04:49 PM
EG1834's Avatar
Default Those of you with a b18b in an eg...
I'm trying to finish my swap that I started before I went to Iraq and running into trouble. Could someone please post a pic of the vacuum lines on the manifold. The d15 motor had 2 vacuum ports on the throttle body and the B18 only has 1 port. Any help is greatly appreciated.
Old Nov 15, 2005 | 05:21 PM
EG1834's Avatar
Default Re: Those of you with a b18b in an eg... (EG1834)
[IMG][/IMG]
I'm guessing that sensors #1 and #2 are the same?
[IMG][/IMG]
#3 is the vacuum port thats not on the B18 throttle body. Instead there's sensor #2 above.
Old Nov 15, 2005 | 05:47 PM
EGDC2CIVIC's Avatar
#1 and #2 are the same, #1 is no longer needed and used to plug into #3( with your d15)
Old Nov 15, 2005 | 05:59 PM
EG1834's Avatar
I understand that the vacuum line from #1 went to the port at #3 when the d15 was in there, but what I don't get is what to do with #1 and #2. Since they're the same, do I unplug #1, or #2, or what? Also, did you have any problems with the del sol radiator hose fitting your civic radiator?
Old Nov 15, 2005 | 06:13 PM
EGDC2CIVIC's Avatar
Modified by EGDC2CIVIC at 9:29 PM 11/15/2005
Modified by EGDC2CIVIC at 9:34 PM 11/15/2005
snowblind7x
Jul 21, 2013 11:41 AM
B18B_EJ1
Jul 10, 2011 03:34 AM
prelude9999
Oct 8, 2004 10:01 AM
nwisehart
Apr 22, 2003 10:18 AM
