how can i tell if i jump a tooth
Old Nov 15, 2005 | 04:14 PM
lv6l's Avatar
Default how can i tell if i jump a tooth
i have a 94 civic cx. all stock. i think my timing belt jump a tooth, i want to know how can i tell if it jump or not by looking at it?? thanks.
Old Nov 15, 2005 | 04:22 PM
LVB18Civic's Avatar
Default Re: how can i tell if i jump a tooth (lv6l)
Turn the motor over until the white mark on the crank pulley lines up with the mark on the lower timing cover. Then remove the upper timing cover and check to see if the upper marks are lined up. If any of the marks are off you know that it jumped.
Old Nov 15, 2005 | 05:10 PM
evade this honda's Avatar
sucks if it did.
Old Nov 15, 2005 | 07:30 PM
lv6l's Avatar
my mark color on my crank pully are faded out. i see 5 lines. l l l l l. in the sets of 3 lines, the middle line is RED.
Old Nov 15, 2005 | 07:39 PM
Soccerking3000's Avatar
Default Re: (lv6l)
it'll run like complete **** and the timing will be way off. But as stated before make sure the marks on the crank line up and the 2 lines on the cam gear are parallel to the head
Old Nov 15, 2005 | 07:56 PM
lv6l's Avatar
i have 5 lines, do i line up the crank pully's middle line of the 3 sets? (same line i lined up when i do my timing?)
Old Nov 16, 2005 | 12:04 PM
lv6l's Avatar
bump
Old Nov 17, 2005 | 12:33 PM
butt_munch024's Avatar
check to see if number1 piston is at tdc with#1 at top you will see if crank lines up with cam
lv6l
Nov 17, 2005 04:41 PM
Power Rev Racing
Aug 15, 2005 04:45 AM
Kirt Porter
Oct 8, 2004 09:10 PM
JONBLAZE55555
Nov 27, 2003 09:09 AM
ScottEK
13
Sep 25, 2002 08:23 PM
