Rethreading my gsr head?? exhaust manifold side stripped up the booty
i recently took off the bolts from the exhaust manifold and all i saw on the thread of the bolts were little pieces of metal thats wrapped around the bolt...now all of the bolts are loose and has been stripped and now i have boost leak like crazy...is there anything i can do to fix this problem? im planning on switching to all double sided threaded studs and use nuts to tighten...will i have to rethread the head to a bigger size like 10mm? any comments or ideas are greatly appreciated. Thanks
