B16A2 Cams Question.....
I got B16A2 its out of the car, i want to put type r cams, i took the old cams out but i heard before u take them out u have to put the 1st piston TDC, well i didnt do that, is that bed? or it doesnt matter ? i know the torque and all that but i just forgot to do that. Can u guyz help me thanx in advance !!
Is the crank pulley still on? if it is rotate the motor till it lines up with tdc mark on the timing cover. Then you should be good to go. Make sure you install the cam gears in the up postion. Anybody tell me if Im wrong.
Bashy Vtec
Sep 17, 2015 02:30 PM
