car starts, wont stay started if i let key go!!
Old Nov 14, 2005 | 11:19 AM
vast01's Avatar
Default car starts, wont stay started if i let key go!!
1994 Honda Accord EX 4 door
mostly stock besides audio and suspension
Ok - problem started yesterday, while i came to a stop at a light, car died. no stalling noises, no chugging, just off. after 5mins of cranking, it started back up again. not 2 km down the street, just right off again. Thought it was gas gauge, dad came and filled me up 1/4 tank, still no go. car would crank and fire, but would quickly turn off again.
At this point after some fiddling, i figured out if i keep the key in the START position, the car will stay on. So, i drove it home this way. Now, i've done some research, and figured it was my main relay, but when i turn the key over, i do hear it click.
Last thing i should mention, when the car is being turned over, the accessories (air, stereo) are off until i release the key just a tiny bit, at which point they will turn back on. when i release the key some more back to the RUN position, back off it goes.
I hope this explains the whole problem, if i should add any more, please request.
thank you very much
jay
Old Nov 14, 2005 | 11:41 AM
Ross 2.0's Avatar
In a Junkyard near you.
You need to replace the electrical side of your ignition switch. Everything is supposed to be off while cranking to direct the most power to the starter.
Old Nov 14, 2005 | 12:08 PM
Schmitey's Avatar
Default Re: (MooGoCow3)
yeah, hence your radio cuts out when you start it etc.
going out on a limb here but didn't some years have a safety recal on the ignition switch?, i know some of the civics did
Old Nov 14, 2005 | 01:04 PM
P_Adams's Avatar
Default Re: car starts, wont stay started if i let key go!! (vast01)
Yup, Listen to Bender (oops "MooGoCow3")
He's got it correct. The electrical portion of the switch assembly sh..t the bed.
Refer Illustration link:
http://www.hondaautomotivepart...81%29
P
Old Nov 14, 2005 | 04:12 PM
Ross 2.0's Avatar
Just FYI I would definately stay away from parts store ignition switches. Those arent any good. You need this from your dealer. It may cost a little more but it's going to be the last one you buy. As far as a recal you can give me your VIN # and i'll be able to look it up for you. But i'm pretty sure the recall is above your year.
Most Honda's will get a new ignition switch one time in it's life.
cooleyhigh12
Dec 10, 2012 07:01 PM
bobmugen
Aug 22, 2012 01:27 AM
jim9
Nov 3, 2007 06:24 PM
Meatwad1355
Jul 1, 2007 08:12 AM
Darren804
Oct 3, 2001 08:27 AM
