installed b18c1 into gsr......tons of problems!!!!!!PLEASE HELP~~
Old Nov 13, 2005 | 03:40 PM
ne0z3r's Avatar
Default installed b18c1 into gsr......tons of problems!!!!!!PLEASE HELP~~
first of all......bought the rolling chassis w a type r front clip........bought a b18c1 to install in it.......
installed b18c1........but here's the problems....any suggestions are welcome.
car does crank and run.
neither the a/c compressor nor the condensor fan will turn on......
the blower motor work when ever the crap it wants.....turns on and off irradically.
the cooling fan doesn't turn on, tested fan with 12 volt, it works. getting power at relay in fuse box, temp sensor has power.......
no check engine lights.....
rpm cluster and speedometer cluster doesn't work but temp and fuel do....
please help me!!!!
thank you in advance.
Old Nov 13, 2005 | 04:50 PM
94DOHCGsr's Avatar
Default Re: installed b18c1 into gsr......tons of problems!!!!!!PLEASE HELP~~ (ne0z3r)
Do you have power going to the ac for the clutch to engage?
Old Nov 13, 2005 | 05:54 PM
slo blue's Avatar
Default Re: installed b18c1 into gsr......tons of problems!!!!!!PLEASE HELP~~ (94DOHCGsr)
check for a loose ground
Old Nov 13, 2005 | 06:30 PM
gsr dood's Avatar
Default Re: installed b18c1 into gsr......tons of problems!!!!!!PLEASE HELP~~ (slo blue)
for ur speedo make sure the vss VEHICLE SPEED SENSOR is plugged in the tranny
97civicowner
34
Aug 27, 2018 06:09 PM
haribells
Jul 30, 2014 03:41 AM
808zrk
Sep 2, 2012 08:47 PM
baonest
Sep 6, 2005 07:59 AM
fanta!
Jul 16, 2005 12:47 PM
