Vibrating Shifter
Old Mar 11, 2002 | 05:49 AM
GruvyTune's Avatar
New User
Default Vibrating Shifter
when driving on the highway past 70MPH, I get vibration in my shifter. Only happens at higher speeds. Makes an annoying noise. I took off the boot and greased the hell out of it but that didn't solve the problem. I don't see anything hitting it under the car--like a heat shield or something.
Any way to cure this?
Old Mar 11, 2002 | 05:54 AM
Jesse H's Avatar
Default Re: Vibrating Shifter (GruvyTune)
replacing the bushing might help, and the shifts will feel more precise
Old Mar 11, 2002 | 05:57 AM
b18bvtec4drteg's Avatar
Mine does it too. Its the bearing thats under the shifter (under the ball thingy) where the bolt goes across. Maybe time to switch to a shorty..
Old Mar 11, 2002 | 06:54 AM
GruvyTune's Avatar
New User
Default Re: Vibrating Shifter (b18bvtec4drteg)
bearing or bushing??
Do you know exactly which parts need replacing so I can order them?
The sound is annoying me!
Never replaced my shifter bushing, is it difficult to do? Will I need access to a press to do it?
Not sure if I need a short shifter, I like the stock shifter on my GSR.
thanks
Torin
Old Mar 11, 2002 | 08:25 AM
Kamin's Avatar
replace the bushing first (cheaper and will help anyway)
not that bad to do but if the bolts are rusted its a PITA.
MiamiEgGSr
Nov 4, 2007 04:37 PM
slash00R
Nov 1, 2004 07:23 PM
CrX-To-Tha-Max
Mar 17, 2004 11:10 AM
xaznx
Nov 1, 2002 10:12 AM
94tegAddict
May 12, 2002 06:23 PM
