LS/VTEC Oil Leak
I've been noticing that my car has had a oil leak for a little while now but I finally have some spare time to fix it. It gets really bad when I get on the throttle. I know it is coming from the back of the block somewhere but I can't quite figure out where.
I got under the car today and noticed that there was drops of oil on the bottom of the intake manifold. I thought maybe it was the fitting that connected into the sandwhich plate that was leaking so I took it out and put some teflon tape on it. I made sure the mating surfaces were nice and clean as well. Im stumped on where the oil leak is coming from. When I come to a stop after getting on the throttle there is quite a bit of smoke coming out from under my hood from oil dripping onto my header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20accord »</TD></TR><TR><TD CLASS="quote">damn what is it with ls-vtec setups always having problems like this. I doubt it is your valve cover gasket. </TD></TR></TABLE>
what is it with people doing shoddy jobs putting lsvtecs together, causing them to have problems like this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">
hahaa my **** dont leak!!
**Knock on wood** but yeah build it right saves you money and time!!!!
</TD></TR></TABLE>hahaa my **** dont leak!!
Ok I found the leak... turns out it wasn't any of the LS/VTEC stuff at all. The machine shop that I took my block to took the fitting that is back behind cylinder #3 off and never put it back on... and when I assembled my motor I completely missed that! Got it all hooked up and its running great now.
keilux
53
Aug 17, 2009 05:43 PM
JDMgunmetalCRX
Jul 8, 2009 12:49 AM
