QUICK question abotu headers
Old Nov 12, 2005 | 04:16 PM
roundworldsobig's Avatar
Default QUICK question abotu headers
did the 94 integra come with 4-2 and 2-1 headers? does the 94 year headers fit on a 98? need to know asap!
Old Nov 12, 2005 | 04:28 PM
stewmaster-k's Avatar
Default Re: QUICK question abotu headers (roundworldsobig)
they didn't come with headers stock, but you can order a 4-2-1 or a 4-1 header for it. as far as will it fit a 1998, i'm not to sure but i know that if they are both the b18b or both the b18c, then it will work.
Old Nov 12, 2005 | 04:35 PM
IVI's Avatar
IVI
Default Re: QUICK question abotu headers (stewmasterk)
all b-series parts should be interchangable but the connector to the cat may be diffrent and you may have to goto a weld shop.
Old Nov 12, 2005 | 04:45 PM
fergy016's Avatar
98-01 the 2 o2 sensors are in the catalytic converter, where are they in previous models?
Old Nov 12, 2005 | 05:38 PM
projectTeG's Avatar
i believe here in the US they came with 4-2-1 cast manifolds.
Old Nov 12, 2005 | 07:15 PM
purplegsr's Avatar
If you get any 94-01 LS/RS/GS/SE, 97-98/00-01 ITR or 00-01 GSR stock exhaust manifold (a.k.a. header), it will fit your 98 LS. Your car is obd2, so it has 2 o2 sensors, one on the cat, and one on the header at the collector. All of the manifolds I listed above have the same setup. You cannot get a stock manifold from a 94-99 GSR though, as it has no o2 sensor in the header and will not bolt up to your cat. So, for you purposes, as long as the 94 you are talking about is non-gsr, it will work.
fergy016 - only 96-99 gsrs have two o2 sensors in the cat, every other 96+ integra, incl the 00-01 gsr had 1 in the cat, 1 in the header, as described above.
Old Nov 12, 2005 | 10:00 PM
blackdelslo's Avatar
Default Re: QUICK question abotu headers (purplegsr)
Ok so if you have header(s), where does the 2nd one go on your four banger?
Old Nov 16, 2005 | 07:42 AM
fergy016's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">fergy016 - only 96-99 gsrs have two o2 sensors in the cat, every other 96+ integra, incl the 00-01 gsr had 1 in the cat, 1 in the header, as described above.</TD></TR></TABLE>
thank you for the knowledge, I have always wondered!
Old Nov 16, 2005 | 08:40 AM
TunerN00b's Avatar
Default Re: QUICK question abotu headers (delLudeVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Ok so if you have header(s), where does the 2nd one go on your four banger?</TD></TR></TABLE>
Technically, each individual pipe is a header pipe, thus the 4 of them together can correctly be called headers. Header is also correct, as it is a single unit after being welded together.
Sorry, couldn't resist, even though I add nothing meaningful to the thread.
Wrath of VTEC
Nov 4, 2014 10:50 PM
teggrl
Oct 19, 2007 08:03 PM
dan's integra
Jun 28, 2006 11:29 PM
h45454
May 12, 2003 02:47 PM
MugenGTR
Aug 18, 2002 03:16 PM
