valve lash question for LS??
Hey eveyone. im sure there are alot of "Valve Lash" questions but i got one for the LS motors. Im running a PR4 head B18B block and it calls for a .003 intake and .006 for exhaust. I set them to those settings and Alot of smoke comes out. I think I did the lash LAST TIME for the B18A settings at .007 intake and .008 exhaust and I think that worked fine.
My valves set too tight would make ALOT of smoke come out?? I think im going to try the .008 setting all around for the B18B.
anybody know why the B18B and B18A have different valve lash settings???
Thanks.
Thanks.
not it..... car smokes like a *****. i think i got the valve lash wrong. I dont have a manual.
anybody know the lash?? I think its .006 intake and.007 exhaust??
is that write??
I have a PR4 head
is that write??
I have a PR4 head
The B18A and B18B are:
Intake .003-.005
Exhaust .006-.008
B18C and B16A are:
Int .006-.007
Exh .007-.008
You had it right the first time, so I think the excess oil was your problem, and if it doesn't go away, you may have damaged something like All Motor Coupe said.
Intake .003-.005
Exhaust .006-.008
B18C and B16A are:
Int .006-.007
Exh .007-.008
