valve lash ???
Old Dec 20, 2006 | 06:54 PM
DB1_559's Avatar
Default valve lash ???
ok i got a b18b head on a b18a block i was wondering my valve lash are set for b18a head specs is there a differnt between the two head
Factory spec for the B18B and B20B/Z is:
Intake: 0.003"-0.005"
Exhaust: 0.006"-0.008"
factory spec for the b18a1 is:
intake:0.005-0.006
exhaust:0.007-008
Old Dec 20, 2006 | 09:39 PM
kazman's Avatar
Default Re: valve lash ??? (jdmboi86)
if you're are using a b18b head i'd go with the b18b specs for the valve lash just my 2 cents
Old Dec 20, 2006 | 09:53 PM
youdontknowmeeither's Avatar
well, the blocks are the same as far as bore and stroke, so the piston should go up to the same height you'd think. so it'd make sense that the reasoning for the differences in valve lash has to do with the head. so yeah, b18b specs i'd think.
Old Dec 20, 2006 | 10:34 PM
DB1_559's Avatar
ok kool cause its at b18a specs gonna give it a try to see what happens
Old Dec 21, 2006 | 05:59 AM
Sam92Teg's Avatar
I have a B18A and the Helms states .003-.005 Intake and .006-.008 Exh
Don't know where you got your B18A specs from.
Edit: the specs you gave for the B18A are for the VTEC B17A1, well close:
.oo6-.007 In
and .007-.008 Ex
Old Dec 21, 2006 | 08:20 AM
http://www.team-integra.net/se...D=485
Old Dec 21, 2006 | 12:41 PM
Sam92Teg's Avatar
Default Re: valve lash ??? (zachlange)
Those specs might be for the 90-91 (130hp) version of the B18A in that thread.
The 92-93 (140hp) version is definitely what I posted.
Old Dec 21, 2006 | 01:11 PM
DB1_559's Avatar
oh my bad that spec was a guess lazy to get my helms but my lash is off on the intake its at .6
highliner82
Dec 10, 2010 09:31 AM
Octoman
May 20, 2004 03:12 PM
metal-x
Mar 12, 2003 01:55 PM
daver
Oct 29, 2002 07:17 PM
