Bosch and Denso Wiper Blades - Hundreds in stock!!
Old Nov 12, 2005 | 12:53 PM
prostreetonline's Avatar
Default Bosch and Denso Wiper Blades - Hundreds in stock!!
We have hundreds of wiper blades in stock for virtually every make and model! All are in stock, ship the same day, and are the highest quality wiper blade you can buy!!
Q. How often should wipers be changed?
A. Wipers should be changed when they no longer perform as expected, or no longer provide a high enough level of safety. The recommended replacement interval for preventive maintenance is 6 months. The exclusive dual-rubber technology of Bosch Micro Edge Excel can extend this interval to as much as 12 months.
<FONT COLOR="blue">Buy Wiper Blades and other OEM Parts here</FONT>
More replacement parts:
Acura Back-Up Light Switch | Honda Back-Up Light Switch
Acura Battery | Honda Battery
Acura Battery Cable | Honda Battery Cable
Acura Flasher Relay | Honda Flasher Relay
Acura Fog Light | Honda Fog Light
Acura Fog Light Bulb | Honda Fog Light Bulb
Acura Fog Light Relay | Honda Fog Light Relay
Acura Fuel Pump Relay | Honda Fuel Pump Relay
Acura Fusible Link | Honda Fusible Link
Acura Headlight Assembly | Honda Headlight Assembly
Acura Headlight Bulb | Honda Headlight Bulb
Acura Headlight Motor Relay | Honda Headlight Motor Relay
Acura Headlight Sealed Beam | Honda Headlight Sealed Beam
Acura Oil Pressure Sender | Honda Oil Pressure Sender
Acura Park Light Assembly | Honda Park Light Assembly
Acura Relay | Honda Relay
Acura Speedometer Transmitter | Honda Speedometer Transmitter
Acura Stop Light Switch | Honda Stop Light Switch
Acura Sunroof Relay | Honda Sunroof Relay
Acura Turn Signal Assembly | Honda Turn Signal Assembly
Acura Water Temperature Sender | Honda Water Temperature Sender
Acura Wiper Blade | Honda Wiper Blade
Acura Wiper Blade Insert | Honda Wiper Blade Insert
Modified by prostreetonline at 4:28 PM 1/1/2006
Old Nov 16, 2005 | 09:43 AM
bump!
Old Nov 22, 2005 | 09:05 AM
http://www.prostreetonline.com/oem/
Old Nov 25, 2005 | 12:17 PM
Old Nov 25, 2005 | 03:36 PM
VTECisSeXY's Avatar
*insert here*
Default Re: (prostreetonline)
excellent seller
Old Nov 29, 2005 | 10:28 AM
Default Re: (VTECisSeXY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECisSeXY &raquo;</TD></TR><TR><TD CLASS="quote">excellent seller </TD></TR></TABLE>
Thank you!!
Old Nov 29, 2005 | 12:38 PM
dawalude's Avatar
i dont see wiper blades on the site after entering the type of car i have?
Old Nov 29, 2005 | 12:40 PM
Default Re: (dawalude)
In the search box, type "Wiper" or click on "body electrical"
Old Nov 29, 2005 | 03:34 PM
dawalude's Avatar
thanks!
Old Dec 2, 2005 | 10:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawalude &raquo;</TD></TR><TR><TD CLASS="quote">thanks! </TD></TR></TABLE>
Updated the link.. should help
Old Dec 8, 2005 | 09:02 AM
bump!
Old Dec 13, 2005 | 09:48 AM
Thank you for your orders!
Old Dec 15, 2005 | 09:39 AM
bump!
Old Dec 21, 2005 | 10:08 AM
thank you for your orders!
Old Dec 23, 2005 | 09:44 AM
bump!
Old Dec 24, 2005 | 08:56 PM
tony n.'s Avatar
Default Re: Bosch and Denso Wiper Blades - Hundreds in stock!! (prostreetonline)
how much is shipping
Old Dec 26, 2005 | 06:49 PM
.water's Avatar
Default Re: Bosch and Denso Wiper Blades - Hundreds in stock!! (Boosted2Cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2Cam &raquo;</TD></TR><TR><TD CLASS="quote">how much is shipping</TD></TR></TABLE>
and, when i replace i can just replace the rubber part?
there are too many OEM..Witch one is the factory OEM part #? for 00 accord se
Old Dec 27, 2005 | 05:43 PM
Default Re: Bosch and Denso Wiper Blades - Hundreds in stock!! (zzzkangzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zzzkangzzz &raquo;</TD></TR><TR><TD CLASS="quote">
there are too many OEM..Witch one is the factory OEM part #? for 00 accord se</TD></TR></TABLE>
yep, just get the insert
Old Dec 29, 2005 | 05:41 PM
Old Jan 1, 2006 | 03:28 PM
bump!
Cosworth
Jan 8, 2003 07:27 PM
stealthteg
Apr 24, 2002 02:55 PM
