Replacement headlights - Hundreds in stock...
High quality OEM replacement headlights! We have them in stock, and ready to ship.
Below are some pics of only a few of the models we carry...
To find prices, and applications, click here:
<FONT COLOR="blue">Headlight Assembly Applications and Prices</FONT> <-- enter your make and model, then under Body and Electrical, click on Headlight Assembly
More replacement parts in this category:
Acura Back-Up Light Switch | Honda Back-Up Light Switch
Acura Battery | Honda Battery
Acura Battery Cable | Honda Battery Cable
Acura Flasher Relay | Honda Flasher Relay
Acura Fog Light | Honda Fog Light
Acura Fog Light Bulb | Honda Fog Light Bulb
Acura Fog Light Relay | Honda Fog Light Relay
Acura Fuel Pump Relay | Honda Fuel Pump Relay
Acura Fusible Link | Honda Fusible Link
Acura Headlight Assembly | Honda Headlight Assembly
Acura Headlight Bulb | Honda Headlight Bulb
Acura Headlight Motor Relay | Honda Headlight Motor Relay
Acura Headlight Sealed Beam | Honda Headlight Sealed Beam
Acura Oil Pressure Sender | Honda Oil Pressure Sender
Acura Park Light Assembly | Honda Park Light Assembly
Acura Relay | Honda Relay
Acura Speedometer Transmitter | Honda Speedometer Transmitter
Acura Stop Light Switch | Honda Stop Light Switch
Acura Sunroof Relay | Honda Sunroof Relay
Acura Turn Signal Assembly | Honda Turn Signal Assembly
Acura Water Temperature Sender | Honda Water Temperature Sender
Acura Wiper Blade | Honda Wiper Blade
Acura Wiper Blade Insert | Honda Wiper Blade Insert
Modified by prostreetonline at 4:29 PM 1/1/2006
Re: Replacement headlights - Hundreds in stock... (prostreetonline)
Make: Honda
Year: 2000
Model: 1.6 Si 2Dr
Body & Electrical
Part
Battery
Battery Cable...
Flasher Relay
<U>Headlight Bulb</U>
Oil Pressure Sender
Relay...
Sunroof Relay
Wiper Blade...
That's all I see?
Year: 2000
Model: 1.6 Si 2Dr
Body & Electrical
Part
Battery
Battery Cable...
Flasher Relay
Oil Pressure Sender
Relay...
Sunroof Relay
Wiper Blade...
That's all I see?
Re: Replacement headlights - Hundreds in stock... (2000EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000EM1 »</TD></TR><TR><TD CLASS="quote">Make: Honda
Year: 2000
Model: 1.6 Si 2Dr
Body & Electrical
Part
Battery
Battery Cable...
Flasher Relay
Oil Pressure Sender
Relay...
Sunroof Relay
Wiper Blade...
That's all I see? </TD></TR></TABLE>
Weird... do you know if the 99-00 Si lights are different than the 98 EX?
Here are the EX:
http://www.prostreetonline.com...embly
Year: 2000
Model: 1.6 Si 2Dr
Body & Electrical
Part
Battery
Battery Cable...
Flasher Relay
Oil Pressure Sender
Relay...
Sunroof Relay
Wiper Blade...
Here are the EX:
Yeah they'll be different. Any headlight assembly for a 99-00 should work on my car, but 96-98s are different than 99-00s though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000EM1 »</TD></TR><TR><TD CLASS="quote">Yeah they'll be different. Any headlight assembly for a 99-00 should work on my car, but 96-98s are different than 99-00s though. </TD></TR></TABLE>
Ah... ok, I just found out that it's not showing up because we are currently out of stock on them... Prelude as well... more on the way though... check back later, once our shipment is scanned in, it'll be added to the site automatically!
Do you know a price? I'm really just looking for a really cheap set to do a DIY blackout paint job on so I still have my stock ones incase I fugg them up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000EM1 »</TD></TR><TR><TD CLASS="quote">Do you know a price? I'm really just looking for a really cheap set to do a DIY blackout paint job on so I still have my stock ones incase I fugg them up. </TD></TR></TABLE>
Should be the same price as the 96-98
Re: (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">They're 40$ less than OEM Honda brand new are these DOT/SAE approved?</TD></TR></TABLE>
Yep... for the Honda/Acura they are made by TYC which is an OEM supplier, so they are DOT/SAE approved.
Thank you!
Thank you!
Re: (draxxus07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by draxxus07 »</TD></TR><TR><TD CLASS="quote">hey would you guys carry the headlights for the 97-01 preludes? and how much? thanks</TD></TR></TABLE>
Unfortunately, the headlight assemblies are currently not in stock, all we carry are the bulbs right now:
http://www.prostreetonline.com...+Bulb
Re: (prostreetonline)
not trying to bring teh thread down by why would it cost me $800.02 for new headlighst for my 94 integra rs. i'm sorry but that just seems crazy insane
