who runs a restrictor with FASTURBO oil lines?
Old Nov 12, 2005 | 12:50 PM
RACEPAK's Avatar
Default who runs a restrictor with FASTURBO oil lines?
hello everybody...
how can i know if i need a restrictor for on my feed oil line?
before a week or so my car started smoking from the tailpipe...
i removed the downpipe and i found oil in it (no oil in charge pipes). what cold it be besides high oil pressure?
the return line isnt kinked....
thanks.
Old Nov 12, 2005 | 02:50 PM
RACEPAK's Avatar
Default Re: who runs a restrictor with FASTURBO oil lines? (RACEPAK)
ttt cause i need to buy arestrictor tommorow morning
Old Nov 12, 2005 | 03:09 PM
h22 civic's Avatar
turbonetics or garrtet? dual bb singlebb or 360 racebearing?
Old Nov 12, 2005 | 09:50 PM
RACEPAK's Avatar
Default Re: who runs a restrictor with FASTURBO oil lines? (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">turbonetics or garrtet? dual bb singlebb or 360 racebearing?</TD></TR></TABLE>
garrett
Old Nov 13, 2005 | 02:54 AM
RACEPAK's Avatar
which size of restrictor should i get?
Old Nov 13, 2005 | 02:55 AM
JDM00SI's Avatar
keep me updated...im probably going through the same process.
Old Nov 13, 2005 | 08:34 AM
eg:R's Avatar
i want to know to, going to be putting my setup in soon. i have a garrett gt30r. will i need a oil restrictor?? is it better to break in a motor with the turbo setup hookup or after.
Old Nov 13, 2005 | 08:49 AM
RACEPAK's Avatar
Default Re: (eg:R)
somone is making for me the restrictors... i told him to make .060 and .050 i will get em tommorow.... the sizes are ok right?
Old Nov 13, 2005 | 01:07 PM
Pandahatch's Avatar
I've seen people using .055, so the .060 should be good to go.
Old Nov 14, 2005 | 02:11 AM
RACEPAK's Avatar
Default Re: (PandaHatch)
ok so i used the .050 restrictor and i let it idle a bit to burn the old oil...
there is still smoke but alot less then before... should i try .040 or mabey smaller ????
Old Nov 14, 2005 | 04:01 AM
RACEPAK's Avatar
Default Re: (RACEPAK)
^^^bump cause really need to know...
Old Nov 14, 2005 | 07:30 AM
RACEPAK's Avatar
bumppppppp
Old Nov 14, 2005 | 10:43 PM
JDM00SI's Avatar
does the gt35e have a oil resistor?
Old Nov 14, 2005 | 10:48 PM
RACEPAK's Avatar
Default Re: (JDM00SI)
its not a gt35
Old Nov 14, 2005 | 11:01 PM
elpiar's Avatar
If you have .050" and still smoking most likely your seals are already blown and need a rebuild.
Boosted_B_Series
Aug 24, 2009 06:18 PM
JDMeg95
Nov 9, 2007 10:44 PM
Boosteddb8
Aug 17, 2006 02:35 PM
Ad4mGSR
Jul 23, 2004 01:15 PM
Pfieff
Mar 7, 2004 02:08 AM
