HELP gsr owners!!!help
Old Nov 12, 2005 | 12:23 PM
nighthawkgsr's Avatar
Default HELP gsr owners!!!help
i drive a 01 gsr and yesterday i was driving on the freeway and downshifted from fifth and forth i noticed my clutch became softer. also when i made it home my idle was below 1000 close to 500 when i rev it to only 2000 it dies. i only have a intake on the car right now so i don't know whats wrong. no check engine light. just got a oil change in the dealership. any help would be greatly be appreciated. thank you
Old Nov 12, 2005 | 12:35 PM
97CGPintegra's Avatar
Default Re: HELP gsr owners!!!help (nighthawkgsr)
where does you car normally idle at? does your car completely shut off at 2000rpm?
Old Nov 12, 2005 | 01:19 PM
Default Re: HELP gsr owners!!!help (97CGPintegra)
i idles normally at about 1500rpm.
Old Nov 12, 2005 | 01:28 PM
purplegsr's Avatar
Your idle should not be that high, 1500 might be while it's warming up, but at operating temp, your idle should be around 700 (the third line below 100) - You will notice that the lowest line is actually 500rpm. If you are idling at 500, your car is about to stall.
check your oil level, since it was just changed. It should be halfway between the 2 dots or so. When you say you downshifting from 'fifth and fourth', do you mean from 5th to 4th? or from 5th and 4th into other lower gears?
94DOHCGsr's Avatar
thats an abnormaly high idle...fully warmed up it should idle at 600-760 rpm. Plus in vegas it is still probably about 80 since it is still 65-70 degrees.
It could be many things. And did it happen right after u got the oil change at the dealer or a few days later?
Old Nov 12, 2005 | 01:36 PM
Default Re: HELP gsr owners!!!help (94DOHCGsr)
it happened after i downshifted from 5 to 4 after that my idle went to **** and i had to keep reving the motor to keep it from dieing till i got home. do you guys think this is a quick fix type problem or a expensive one. thanks for the help everyone!
Old Nov 12, 2005 | 01:39 PM
purplegsr's Avatar
is it possible you downshifted from 5 to 2? and not 5 to 4? Misshifts are not prevented by the rev limiter in such situations, and often damage the motor severely. Your best bet is to check your oil level to make sure it's not the dealer's fault, and then do a compression test to see if you get decent numbers for each cylinder.
Old Nov 12, 2005 | 01:45 PM
a day ago my buddy used my car and shifted from 5 to 3 i think or mishifted from 5 to 2 what does that cause the engine to do?
Old Nov 12, 2005 | 01:53 PM
purplegsr's Avatar
5-2 misshift will caus your engine to overrev and your valves will end up bent. Definitely do a compression test, and ask your friend exactly what happened.
Old Nov 12, 2005 | 04:34 PM
hmmm you sound like a dumb *** shifting from 5th to 2nd. who the heck does that, unless you purposely want to mess up your car. i don't know why your car wouldidle low like that. but check your air in take it may be loose and may be allowing more air than needed causing it to idle to low and stall. if thats not the problem your screwed and i suggest you get a engine rebuild.
Old Nov 12, 2005 | 04:37 PM
mjc1055's Avatar
Default Re: (nighthawkgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighthawkgsr &raquo;</TD></TR><TR><TD CLASS="quote">hmmm you sound like a dumb *** shifting from 5th to 2nd. who the heck does that, unless you purposely want to mess up your car. i don't know why your car wouldidle low like that. but check your air in take it may be loose and may be allowing more air than needed causing it to idle to low and stall. if thats not the problem your screwed and i suggest you get a engine rebuild.</TD></TR></TABLE>
er... come again?
Old Nov 12, 2005 | 04:49 PM
sorry about that quote my friend jason got into my screen name and type some stupid ****. anyway he is a dumb piece of ****. thanks j!!! i apolize guys thanks for the info. where do i get a compression test done
Old Nov 12, 2005 | 05:05 PM
cimarrondb's Avatar
hi im just curious but it sounds like YOU shifted from 5th to 2nd, and messed up your car, and you used a fake friend as a scapegoat. i'd like to know what you were thinking! shifting from 5th to 2nd( or your supposed friend was thinking ). In fact im sure if my friend did that to my car he would be getting it fixed right now. well anyway you sounded right from your last post, check your air intake. it being an aftermarket part you probably installed it incorrectly or something might have come loose. so i'd recomend that you check that first then do a compression test. check your intake out and let me know how it works, and id also like to know what you or your friend were thinking when you sown shifted from 5th to 2nd.
Old Nov 12, 2005 | 05:21 PM
ITB
Guest
Posts: n/a
when you down shifted did the needle fly all the way up to the red part? if so then you're screwed
your idle shouldnt be at 1500, it should be at 750-800
check if one of your spark plug wires fell out of the distributor. just plug it back and bam, back to normal
Old Nov 12, 2005 | 07:07 PM
purplegsr's Avatar
Default Re:
You can get a compression test done at any regular mechanic shop/gas station with bays/pep boys, etc. It should cost $50 or less, or you can buy the do-it-yourself kit ($20-30), it is basically a pressure gauge with a hose attached and a screw on end. Here is a writeup on how to use it:
http://www.c-speedracing.com/h...t.php
babohyungjin
Mar 25, 2010 01:38 PM
xxi2icexx
Dec 9, 2008 07:48 AM
Sci_v_icI
Mar 4, 2006 08:17 PM
Kooner450r
Dec 27, 2004 09:33 AM
'99luder
Apr 28, 2004 10:36 PM
