Arc welding stainless
Old Nov 12, 2005 | 12:18 PM
karmadhi's Avatar
Default Arc welding stainless
HI , i have been trying to tack up some downpipe with my 200amp arc welder but with no luck. Is there a special electrode I should use in order to tack/weld stainess with an arc? I was thinking that the electrode I am using might be too thick. its around 7mm.
When i try to weld with full power I can see the electrode giving spark and heating up red but no actual or very little melting happens.
I need to tack this downpipe up so I can take it to get tigged.
Thanks
Old Nov 12, 2005 | 03:43 PM
backspin88's Avatar
Default Re: Arc welding stainless (karmadhi)
Well, your electrode has to be a stainless rod. Other than that I'm not sure.
Old Nov 12, 2005 | 05:13 PM
karmadhi's Avatar
Default Re: Arc welding stainless (backspin88)
so I cant even tack using a normal electrode for mild to do stainless?
Old Nov 12, 2005 | 05:38 PM
civicshowracing65's Avatar
you probably can but i wouldn't highly not recommend it. You are trying to using a different electrode that is for steel. One basic thing to think about is that the two metals will expand and contract at different rates when heated and cooled. This could lead to cracking.
Old Nov 13, 2005 | 02:29 AM
karmadhi's Avatar
Default Re: Arc welding stainless (civicshowracing65)
I figured it out, now it works, had a bad ground.
Modified by karmadhi at 8:47 AM 11/13/2005
Vagitarian
Dec 23, 2012 09:46 PM
.john.
Welding / Fabrication
Mar 4, 2008 06:52 AM
dester223
Dec 29, 2005 12:27 AM
jerseydevil
Oct 11, 2004 05:05 PM
94hondaLS
Feb 27, 2003 01:06 PM
