valve cover cutting
Old Mar 10, 2002 | 07:47 PM
erniecars's Avatar
Default valve cover cutting
Ive seen posts on this before but Im wondering how you would cut your valve cover and timing belt cover like this?
[Modified by erniecars, 6:48 AM 3/11/2002]
Old Mar 10, 2002 | 07:54 PM
Dodger2940's Avatar
Default Re: valve cover cutting (erniecars)
I would like you know this also
Old Mar 10, 2002 | 09:13 PM
dirtySOHC's's Avatar
Default Re: valve cover cutting (00B16A2 Si)
wtf? can you edit your post to make some sense.
do you wanna know how to do that to your valve cover?
Old Mar 10, 2002 | 09:31 PM
martini's Avatar
Default Re: valve cover cutting (dirtySOHC's)
I would imagine a holesaw would do the trick.
I cut mine off entirely though, http://www.fatboyraceworks.com/crx/i...e/DSCF0068.jpg
you can actually see the piece still laying on the floor below the engine.
Old Mar 10, 2002 | 09:34 PM
GSRoadRage's Avatar
well you can cuz it by clamping the two togeather and useing a hole saw, or you can draw a half circle pattern on the two and cuz away the material with a die-grinder
Old Mar 10, 2002 | 09:43 PM
H22Si's Avatar
<--- CNC machining baby!
Old Mar 11, 2002 | 07:29 AM
AllMotorMadness's Avatar
go check out : http://www.pmpdesigns.com i think they charge like only $40 if you have the valve cover already...........
toshiyuki
Apr 21, 2017 08:38 PM
AccordSleeperZzZ
Feb 24, 2008 08:37 PM
Okininam
Oct 12, 2006 11:51 AM
Edwin
Jul 24, 2002 12:15 PM
