Sprint Lowering Springs
Since 1995, Sprint Performance Suspension has designed, engineered, inspected, and tested its suspension products in its own extensive facilities. By doing everything in-house, you can rest assured that you are getting lowering springs of the highest quality workmanship, not to mention the accuracy of fitment and handling optimization for each specific street car. Made with the enthusiast in mind, Sprint springs are designed to properly and safely lower your vehicle's center of gravity through the use of proprietary progressive spring rates; reducing squat during acceleration, body roll in the turns, and nose dive under braking. All Sprint springs are shot-peened, heat treated, pre-set, inspected, tested, and performance powder-coated to insure a lifetime of durability. Manufactured in the USA using the finest chrome silicon steel on computerized CNC coil machines, Sprint stands behind its line of ISO 9001 certified lowering springs. With a limited lifetime warranty, Sprint Performance Suspension truly has the engineering and designing expertise that speaks for itself.
Complete kit with 4 springs.
Order here: <FONT COLOR="blue">Sprint Lowering Springs</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. »</TD></TR><TR><TD CLASS="quote">I'm in toronto Canada, I need a set for a 1990 civic Si. 3.25" lowering.
how do i go about ordering them ?
thanks</TD></TR></TABLE>
You can order online... thanks!
