need help identify turbo parts
Old Nov 11, 2005 | 01:09 PM
error's Avatar
Default need help identify turbo parts
i thought this was a t-25 but it wont fit my greddy mani
i know this is a dsm bov, any info on its quality, or specs?
i have no idea what kind of WG this is
if you have any info, go ahead and post it, thx!
Old Nov 11, 2005 | 02:08 PM
B18 CYA's Avatar
wastegate looks like a turbonetics deltagate
Old Nov 11, 2005 | 02:09 PM
hulkhb's Avatar
Default Re: need help identify turbo parts (error)
Turbo looks to have a T3 footplate, not sure what it is though.
DSM BOV - first gen works well under 1 bar after that they have been known to leak, you can push the top of it down, known as 'crushed' it will hold more boost.
the Wastegate is a 35mm Turbonectics, there cheaply made. The brass fitting on the underside of the top where the valve slides into the pressure housing, the brass slide fitting will drop, realeasing boost and causing massive creep.
hope that helps
Old Nov 11, 2005 | 02:15 PM
error's Avatar
Default Re: need help identify turbo parts (hulkhb)
yes that helps alot.
just called a distributor of warner ishi turbos. they told me that it is most likely a rhb-5, good for about 250-275 hp. the downside is that the damn flange on the exhaust is smaller than a t25 fitting. i cant bolt this thing up unless i get a fab'd mani or flange.
iheartjayDem
May 11, 2011 11:08 AM
Orangecivic251
Dec 19, 2006 07:58 PM
adhana2
Apr 15, 2003 06:08 PM
JalopySiR
Nov 22, 2002 11:54 AM
