Need to do some work, To pass inspection
Ok i need to do somework on my brothers 92 accord. It failed inspection. I can do the work, but it would be easier if i had some tutorials or write-ups to help.
Here is a list of what i need to do:
2 axle boots
2 sway bars
Right ball joint
Right head light
Brake pads
& the guy at the inspection place wrote down 2 cylinder? I dont know what he was talking about, and i called tonight but he was not in.
So if anyone could give me some links to write-ups that would be great.
Thanks,
Zach
2 axle boots
2 sway bars
Right ball joint
Right head light
Brake pads
Thanks,
Zach
we do this alot in texas for the axle since its a lifetime warranty...since you need an axle, i have a warranty on the driver side..all u have to do is just go to autozone with your old one and exhange it...pm me
*edit...i have a 95 accord..if it fix a 92 pm me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Este_Cara »</TD></TR><TR><TD CLASS="quote">
*edit...i have a 95 accord..if it fix a 92 pm me.</TD></TR></TABLE>
nope. Looking at around $120 for both after you bring back the old ones (AutoZone)
If you don't own a Manual, don't ******* post!!!
Sorry pal but i totally disagree with you..... would you also say ( if you don't have any tools don't ******* post ) ??? . i mean what is a manual if one does not have any tools right ??
Some of the questions being asked here do not require someone the need to own a service manual,,,,i agree with you that it is very helpful to own it ,,, but to say not to post if they don't own one is overdoing it a bit....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda »</TD></TR><TR><TD CLASS="quote">If you don't own a Manual, don't ******* post!!!
Some of the questions being asked here do not require someone the need to own a service manual,,,,i agree with you that it is very helpful to own it ,,, but to say not to post if they don't own one is overdoing it a bit....</TD></TR></TABLE>
About 1 in 5 tech questions posted up in here can't be answered by a HAYNES manual. Not saying to go out and buy the factory manual which can get pricey... but Jesus... anyone who wants to work on their own vehicle should have a manual of some sort.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zach1288 »</TD></TR><TR><TD CLASS="quote">I can do the work, but it would be easier if i had some tutorials or write-ups to help.
C'mon.... this guy is asking for a manual!!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zach1288 »</TD></TR><TR><TD CLASS="quote">Have any of you replaced an axle on an accord?</TD></TR></TABLE>
yes it's pretty straight forward.
1)Remove the wheel
2)Remove the 36mm nut on hub
3)Remove upper/lower ball joint (your preference
4)pull hub out of the way
5)remove axle
6)reverse to install
1)Remove the wheel
)4)pull hub out of the way
5)remove axle
too much to go into here
