Messed up suspension?
Old Nov 10, 2005 | 10:52 PM
numotive's Avatar
Default Messed up suspension?
Whenever my rear right wheel goes over a bump or hole it sounds like its bottoming out. I have new tokico illimina struts with eibac pro kit springs so it couldn't be that the strut is bad. It did the same thing before when i was running stock struts with my eibac pro kits. For some reason it only does it on the rear right wheel, not any of the others. When I hit a decent sized bump, it makes a lound bang. Any ideas what it could be?
Old Nov 10, 2005 | 11:10 PM
ITB
Guest
Posts: n/a
mine too. it goes THUMP. doesnt sound like bottoming out though. bottoming out sounds more like SCCCRAAAAHHHPPP!SCHEERRSSZZZ. yea its from the rear right too. ahahah i dont think its a problem
Old Nov 11, 2005 | 08:41 AM
numotive's Avatar
Default Re: (ITB)
really? and its only with your rear right wheel as well?
Old Nov 11, 2005 | 09:02 AM
98 Spec R's Avatar
Default Re: Messed up suspension? (numotive)
Maybe your lower control arm is hitting your exhaust. Look at your exhaust to see if it is rubbing on your control arm when your suspension is compressing over a bump. Good Luck
Old Nov 11, 2005 | 07:02 PM
numotive's Avatar
Default Re: Messed up suspension? (98 Spec R)
hmmm.... thats a really good point. i don't remember that happeneing before i installed my Magnaflow catback. the muffler on it is pretty big, i'll check to see if thats it thanks!!
Old Nov 11, 2005 | 07:07 PM
97tegGS's Avatar
I would second the exhaust or if you could get two floor jacks jack the car up somewhat to fit the other under the rear tire and jack it up and after each pump check for issues.
Dont completly use the 2nd jack with the cars wieght on the tire.
Old Nov 13, 2005 | 11:44 AM
numotive's Avatar
Default Re: (97tegGS)
good idea
Old Nov 13, 2005 | 11:45 AM
98 Spec R's Avatar
Default Re: (numotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numotive &raquo;</TD></TR><TR><TD CLASS="quote">good idea </TD></TR></TABLE>
Was that the problem?
Old Nov 14, 2005 | 04:47 PM
numotive's Avatar
Default Re: (98 Spec R)
well while i was installing my comptech sway/tie bar combo this weekend, i looked to see if i could see any marks from the LCA hitting the exhaust and it didn't look like it. i didn't really check very thoroughly though, i'll have to check again. one thing i did notice was the the exhaust tip is actually touching my bumper, and has even melted my bumper a little from the heat. i'm thinking maybe the noise is the exhaust hitting against the bumper? i don't know... i'll have to do some more research.
drew_kousk
Aug 1, 2008 12:17 PM
YoungKadafi
Suspension & Brakes
Apr 16, 2007 09:13 AM
SoullessJapaneseMachine
Dec 17, 2006 04:11 PM
alfaaay
Suspension & Brakes
Oct 10, 2006 04:59 PM
