squeaking.
squeaking.
ok my car used to ride fine until one day my, i guess rear suspension, began to squeak. like every little hump or bump in the road causes this annoying sound. like my music can block it out but i dont like banging all day lol
what can this be? or how can i go about fixing it?
Which car? Any suspension work done recently? Any work done recently at all? Look at your trailing arm bushings. Have a friend push the rear up and down and you listen for where it's coming from.
Steve
Steve
New User
You could try spraying some whit lith on all the bushings, trailing arm, control arm, links, strut, and letting it soak in for a little then wipe the excess off then put another lin layer on and this will condition them a bit and if it these that are squeaking it might fix the problem
Re: (JdelMsolG)
I dunno if that would be a blown shock it might be something other than that but i would be sure to make sure you bounce the car up and down and find out where the squeak is coming from because if you layer it it might now turn out right.
tatmark1
10-10-2007 03:13 PM
yh23
10
05-31-2005 05:11 PM
yellowturbo
03-25-2005 10:45 AM
