lca question
Old Nov 10, 2005 | 04:28 PM
03rc51's Avatar
Default lca question
are ef and eg lca interchangable? ive been looking for new lca and i found some i like but they are only for eg. thanks
Old Nov 10, 2005 | 04:52 PM
crxnj's Avatar
Default Re: lca question (03rc51)
They're just a hair longer (1/16") then the ef arms but they work,and give you added camber..
Old Nov 10, 2005 | 04:56 PM
03rc51's Avatar
so then eg lcas and a camber kit on my ef would work?
Old Nov 10, 2005 | 05:00 PM
crxnj's Avatar
If the camberkit has anchor bolts,,Yes.. Otherwise no
Old Nov 10, 2005 | 05:02 PM
Tyson's Avatar
front or rear?
fronts are different, not compatible.
rears, should actually be the same. not 1/16" longer. ive checked by putting bolts simultaneously through each bushing. but it could be off, 1/16" aint that big difference anyway.
Old Nov 10, 2005 | 05:15 PM
Civic138's Avatar
Default Re: lca question (Mr.speaker)
pick up some of these
http://www.function-7.com/a0-sus-info.html
Old Nov 10, 2005 | 05:25 PM
Tyson's Avatar
Default Re: lca question (Civic138)
or buy fresh new OEM rear ones for $140.
i just did.
Old Nov 10, 2005 | 05:34 PM
03rc51's Avatar
whats the price on the function 7s? i would like to get new rear lcas, energy suspension bushings and a sway bar kit. what kind of sway bar kits can i get for a 90 dx
Old Nov 10, 2005 | 05:38 PM
CRXBart's Avatar
Default Re: (03rc51)
Get a ST bar.
Old Nov 10, 2005 | 05:42 PM
03rc51's Avatar
what do i need in order to put sway bars on a dx. it doesnt have a factory bar.
Old Nov 10, 2005 | 05:48 PM
CRXBart's Avatar
ST bar comes with all hardware. Put one on my old 91 and my new 88 DX hatch beaters. Got one on my 89 crx si too.
Old Nov 10, 2005 | 05:50 PM
03rc51's Avatar
so i guess all the holes are already there just none of the hardware?
Old Nov 10, 2005 | 05:55 PM
Tyson's Avatar
it uses the factory tow hook holes.
the factory swaybar bracket isnt there tho.
Old Nov 11, 2005 | 02:13 AM
CRXBart's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">it uses the factory tow hook holes.
the factory swaybar bracket isnt there tho.</TD></TR></TABLE>
Old Nov 18, 2005 | 04:42 PM
Tyson's Avatar
Default Re: lca question (Tyson)
i just got my NEW OEM rear LCA with fresh new bushings... im drooling over em.. lol. i only paid $130 shipped. hondapartsdeals.com with $10 discount.
i should be getting my front LCA with a new inner bushing pressed in back today. im gonna use ES poly for the bottom shock bushing. (one of only a few places i recommend using poly)
got a whole set of ITR top mount bushings. stiffer than stock.
just need to get my new rear upper control arm bushings pressed in...
complete new bushings!
Old Nov 18, 2005 | 04:58 PM
fourthgenhatchB17's Avatar
i have the ES's there and mine didnt last. I torqued the bolt/nut to factory specs and everything.
And YES the EG and EF rear LCA's are the same length.
GameBoyeas
Apr 20, 2018 10:56 AM
wheelyboard
23
Jul 2, 2012 04:15 AM
davec_84
Apr 6, 2006 06:01 AM
turbotime
Jul 14, 2004 03:43 AM
krazie1
Jun 24, 2004 08:04 PM
